LS flywheel - Team Camaro Tech
post #1 of 12 (permalink) Old Jun 30th, 19, 01:56 PM Thread Starter
LS flywheel
I have been under the impression that i need a .4 thicker flywheel for my LS swap. I expect to go that way but it seems from what i read online not all do. Is it optional?
3d cad is offline
post #2 of 12 (permalink) Old Jun 30th, 19, 02:46 PM
Vega$69's Avatar
Re: LS flywheel
If you are using your OEM 621 bell housing then youíll want the thicker flywheel
LS BH use a standard thickness LS FW
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 12 (permalink) Old Jun 30th, 19, 02:47 PM
Re: LS flywheel
What transmission and what motor (motor year too)
68 Camaro~LSx ~all motor
post #4 of 12 (permalink) Old Jun 30th, 19, 05:53 PM Thread Starter
Re: LS flywheel
Gen4 and TKO600. I have 621 but will use one of my shields if i can get it to line up.
3d cad is offline
post #5 of 12 (permalink) Old Jul 1st, 19, 07:02 AM
DT
Donny
DT's Avatar
Re: LS flywheel
I also used the 621. All McLeod parts, Flywheel, Clutch, Pressure plate, TOB. I'm afraid I cant find the part#'s though.
DT is offline
post #6 of 12 (permalink) Old Jul 1st, 19, 03:37 PM Thread Starter
Re: LS flywheel
Thanks John. It makes sense that the bh has to be the difference i never saw it stated anywhere before.
McLoed seems to be easy to track down in the catalogs. I was kinda figuring on going that way too Donny.
3d cad is offline
post #7 of 12 (permalink) Old Jul 1st, 19, 03:44 PM
Vega$69's Avatar
Re: LS flywheel
I did one with a steel scatter shield. Lakewood. Same dimensions as an aluminum 621. Used the thicker flywheel.
Get the part #s from McLeod but buy from Jegs or Summit for better pricing. To protect distributors McLeod only sells at list price plus shipping.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #8 of 12 (permalink) Old Jul 1st, 19, 04:44 PM Thread Starter
Re: LS flywheel
Ive got a couple of lakewoods floating around. I have to get them on the surface plate and find out how flat and true they are. I figure the 621 is gonna be close. I mainly use Summit. Last i looked jegs website was still driving me nuts and theres no tax dodge with either anymore. Summits return policy is as good as they claim it is too.
3d cad is offline
post #9 of 12 (permalink) Old Jul 1st, 19, 05:32 PM
Vega$69's Avatar
Re: LS flywheel
Yep Jegs website is a PIA.
I look up the part #s on Summit and use the # in the Jegs search box. Did have to pay tax at Summit as they have a store in Nevada and no tax at Jegs but that may have changed.
I often called higher dollar orders into Summit and they would discount the order to match Jegs shipped prices.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 12 (permalink) Old Jul 2nd, 19, 04:44 AM
Steven
stamatisg1977's Avatar
I have the american pwertrain LS 621 bellhousing. Had to use a spacer behind the throwout bearing
All mcleod clutch parts
Stock thickness flywheel
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #11 of 12 (permalink) Old Jul 2nd, 19, 04:38 PM
Re: LS flywheel
I did a quick search and found this for you.....
https://ls1tech.com/forums/conversio...-ls-motor.html
post #12 of 12 (permalink) Old Jul 2nd, 19, 05:31 PM Thread Starter
Re: LS flywheel
Thanks Doug,
I troll over there a little bit but i missed that
3d cad is offline
