LS3 Port Identification - Team Camaro Tech
 2Likes
post #1 of 28 (permalink) Old Jul 24th, 19, 04:46 AM Thread Starter
Bobby
Can someone insure that I know what this port is used for, what gets connected to it?
My YouTube LS3 Engine Swap Page
My LS3 Engine Swap Thread
Sixty8Camaro is offline
post #2 of 28 (permalink) Old Jul 24th, 19, 04:52 AM
Re: LS3 Port Identification
Crankcase ventilation. Connect it to your air intake tube between the MAF and throttle body. It must go after the MAF so the air is metered.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 28 (permalink) Old Jul 24th, 19, 05:25 AM
Vega$69's Avatar
If it goes after the MAF it isnít metered.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 28 (permalink) Old Jul 24th, 19, 05:37 AM
After as defined by the airflow direction. So after the intake air flows through the MAF. Therefore it is metered by the MAF. My statement was correct John. This isnít my first rodeo....
I encourage the OP to read and fully understand the documentation he received with his GMPP LS3 crate engine and harness etc...
dhutton is offline
post #5 of 28 (permalink) Old Jul 24th, 19, 06:50 AM
Vega$69's Avatar
Don. Help me understand.
If air is introduced after the MAF how can it be metered by the MAF?
Vega$69 is offline
post #6 of 28 (permalink) Old Jul 24th, 19, 07:00 AM
Ken
Correct.
Sent from my SM-G965U using Tapatalk
partsguy57 is offline
post #7 of 28 (permalink) Old Jul 24th, 19, 07:19 AM
John, that is where the fresh air flows from the intake tube to the crankcase. You have the air flow direction reversed in your mind.
At least this has long been my understanding. I guess I better not be wrong....
dhutton is offline
post #8 of 28 (permalink) Old Jul 24th, 19, 08:21 AM Thread Starter
Bobby
Thanks, I believe I have a nipple to accommodate the connection.
post #9 of 28 (permalink) Old Jul 24th, 19, 08:23 AM
Yep. What intake kit is that? Looks pretty good.
dhutton is offline
post #10 of 28 (permalink) Old Jul 24th, 19, 08:24 AM
Vega$69's Avatar
So if the port on the valve cover takes fresh air from the intake tube after the MAF the volume of air entering the TB is not the same volume the MAF measured.
Maybe this is offset by the air from the port on the valley cover the is connected to the vacuum side of the TB.
Just curious and wondering?
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #11 of 28 (permalink) Old Jul 24th, 19, 08:59 AM Thread Starter
Bobby
I guess it is from Chevrolet Performance? I think more expensive @ $475 than some other options?
https://www.gmperformancemotor.com/P..._Code=19301246
post #12 of 28 (permalink) Old Jul 24th, 19, 09:02 AM
Ken
It is measured as the air is then sucked down the intake and burned. The air is still used and burned just not ran through the " throttle body " per say.
The air is pulled past the maf ( metered) and then burnt. Air pulled in front of maf is still burnt but not metered
dhutton likes this.
post #13 of 28 (permalink) Old Jul 24th, 19, 09:20 AM
It passes through the MAF then to the valve cover then through the crankcase and finally into the intake through that corrugated tube. No air is lost anywhere in the process. It is just ďdirtyĒ when burned. The vacuum in the intake pulls the air from the intake through the crankcase etc. That is the purpose of the catch can, to capture any oil in that dirty air before it reaches the intake.
dhutton is offline
post #14 of 28 (permalink) Old Jul 24th, 19, 09:24 AM
Ken
Thanks lol your explanation sounds better then mine.. first time I went to hook up I had to think about for a while. To be correct as you said, tap in after maf sensor.
post #15 of 28 (permalink) Old Jul 24th, 19, 12:42 PM
Vega$69's Avatar
Conclusion.
Functionally it will work the same before or after the MAF. The amount of air is so small that not being measured by the MAF doesnít affect anything.
However, Since there is no check valve the correct install location after the MAF is so the MAF does not contaminated from crankcase oil from the port on the valve cover
Sorry sometime I overthink things, says my wife, so in addition accepting the location question I am curious about why.
Vega$69 is offline
