Alternator Wisdom? - Team Camaro Tech
post #1 of 1 (permalink) Old Sep 18th, 19, 01:49 PM Thread Starter
Eric
Alternator Wisdom?
Hi All, I have a 68 with stock subframe, LS1 with Holley engine mounts and crossmember. I started down the Holley accessory bracket path and quickly found out did not have the subframe clearance I needed, (not even close despite Holley's attestations). I returned the Holley stuff and got the Dirty Dingo brackets which bolted up no problem while using a small frame alternator.
The positive post on the alternator I sourced was too close to the subframe for my comfort so I reclocked the alternator which resulted in the connector receptacle being at the 12 o'clock position right up against the block, so no go.
I talked to Dirty Dingo (should have done this first) to see which alternator they suggest and came up with 8206-5AN. Before I buy another alternator has anyone here used the Dirty Dingo lower alternator mount? If so, which alternator worked for you? In addition to this question it really seems a lot of people here have had alternator problems recently. Is there a brand in the sweet spot for price/quality?
Thank you -
1968 Standard Coupe, LS1, T56
2007 Tahoe, Z71, Cold Air & Tune
2001 Silverado, Z71, TSP Cam, Cold Air & Tune
really_n0b0dy is offline
