Fuel System - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 28th, 19, 09:24 AM Thread Starter
Tim
Fuel System
Hoping the LS swap experts can clear up my confusion here:
I was planning on using a new stock tank with the Vaporworx insert to operate a 2010 - 2015 Camaro SS or ZL-1 returnless pump. My LS3 arrived yesterday and while reading the installation instructions it occurred to me that perhaps the E-38 ECM doesn't support PWM fuel control and I may be hosed (no pun intended). All of the GM diagrams I am looking at show a return line which I was not planning on.
I know just enough about this stuff to be dangerous so just trying to clarify what I can and can't do. I believe I can add an aftermarket PWM controller but would prefer not too. Should I just abandon my return-less system or am I off track here?
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #2 of 6 (permalink) Old Sep 28th, 19, 01:04 PM
You'll need the control box from Vaporworx in order to take advantage of PWM. You'll use the wire from the ECU as a signal wire to turn it on, the control box will take care of the rest.
johnny mac 1967 is offline
post #3 of 6 (permalink) Old Sep 28th, 19, 01:29 PM
Re: Fuel System
You can use these if you donít want to use the Vaporworx PWM controller. Gives you returnless 60 psi.
https://www.vaporworx.com/product/fpragm5/
https://www.vaporworx.com/product/g5fpr/
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 6 (permalink) Old Sep 28th, 19, 01:59 PM Thread Starter
Tim
Re: Fuel System
Don -
I actually purchased those pieces to go with the pump I bought so maybe I am good to go? I really only decided to go this route because I had a brand new tank which I had purchased when I was going to go the stroker route. Then I went to the dark side, I mean LS side and thought it would be nice to incorporate my tank with an in tank pump (saw this on Pro-Touring forum) and here we are.
This is what I have so far:
Name:	Gas tank 1.jpg
ID:	229545   Click image for larger version
Name:	Gas tank 2.jpg
post #5 of 6 (permalink) Old Sep 28th, 19, 02:21 PM
Re: Fuel System
Originally Posted by Shannon4570 View Post
Don -
Yes you are good to go. Just use your relay to supply constant 12 volts to the pump.
dhutton is offline
post #6 of 6 (permalink) Old Sep 28th, 19, 02:42 PM Thread Starter
Tim
Re: Fuel System
Well, that's good news! Thanks for the feedback.
