long headers with clearance - Team Camaro Tech
post #1 of 12 (permalink) Old Nov 15th, 19, 07:53 AM Thread Starter
Frank
I'm kind of new on the ls bandwagon and I've been searching but no success. Are there any headers (long) out there that do not hang too low below the subframe (or not at all) for ls motors and/or headers that let you use the mechanical linkage for the clutch ? Any help is appreciated.
Frank.
Frank350 is offline
post #2 of 12 (permalink) Old Nov 15th, 19, 08:01 AM
Peter
Re: long headers with clearance
I have the hooker Blackheart headers. They fit very well if you use the hooker motor mounts. No issues with steering gear box and they tuck up very nicely. I'm using a hydraulic clutch, so I can't help you on that aspect.
Pete
69 Camaro
Owner for 33 years
pwentz3l is offline
post #3 of 12 (permalink) Old Nov 15th, 19, 06:46 PM
I am facing the same issue shortly. I would like to use a mechanical heimed up clutch linkage but its not the hill to die on. What i think i have found looking into this is that no one will tell you their header fits with a zbar installed. Some will tell you Dougs Headers just clear. I believe thats likely the case in the perfect scenario with slider mounts. Dougs acknowledged as much to me but they understandably wont get caught up in that black hole. I should know the answer before spring.
3d cad is online now
post #4 of 12 (permalink) Old Nov 16th, 19, 05:47 AM
chris
I have a 1969 Camaro with 350, power steering, factory clutch setup and no a/c. I'm using Thorley 376Y tri-y headers and they fit great with no clearance issues and tuck nicely underneath with plenty of ground clearance. Believe Doug's Headers are also recommended for first generation camaros. Search "Thorley 376Y" and you should find other testimonies. Hope this helps!
DISREGARD....I didn't notice "LS"...sorry!
4sspd69 is offline
post #5 of 12 (permalink) Old Nov 16th, 19, 06:02 AM
Vega$69's Avatar
Hooker Blackhearts work very well. Also Stainlessworks and DSE
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #6 of 12 (permalink) Old Nov 16th, 19, 12:37 PM Thread Starter
Frank
Ok guys, just want to make sure, the headers you guys are talking about, they work well with the factory mechanical clutch linkage ? That's what I'm most concerned with.
Frank.
Frank350 is offline
post #7 of 12 (permalink) Old Nov 16th, 19, 01:46 PM
Vega$69's Avatar
Frank.
How are your using mechanical Z Bar on the LS Swap? LS Block does not have provisions for the studded ball.
They do make a bolt on ball if thatís what youíre using.
Iíve only used hydraulic so have no idea if the headers mentioned will work with the stock clutch linkage.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #8 of 12 (permalink) Old Nov 16th, 19, 06:36 PM Thread Starter
Frank
that is what I want to do, use my factory mechanical linkage with the bolt on ball, but I'd like to know which headers allow that (clearance wise).
Frank350 is offline
post #9 of 12 (permalink) Old Nov 16th, 19, 07:39 PM
Vega$69's Avatar
Sorry no help from me. Iíve never used the original linkage on any of my LS swaps and donít know personally of anyone that has.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 12 (permalink) Old Nov 16th, 19, 09:23 PM
Dan Lemon makes a header to suit LS, and if they're anything like the headers on my Big block Nova they won't hang low.......but you will pay for them.
They are a very nice product though
PS: I'm running a Z-bar.
rodent4 is offline
post #11 of 12 (permalink) Old Nov 20th, 19, 06:02 PM
Charlie
Don’t mean to hi-jack the thread, following along here-but have a question.
Anyone have experience with an LS swap/ header AND a power rack&pinion with regard to clearance issues?
My '67 basketcase:
vetteman_72 is offline
post #12 of 12 (permalink) Old Nov 20th, 19, 07:03 PM
Vega$69's Avatar
R&P with aftermarket subframe experience.
The only clearance consideration it the steering shaft to the rack. Not hard to resolve. Donít know about R&P with stock sub.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
