Clutch/brake/acc pedal height - Team Camaro Tech
post #1 of 10 (permalink) Old Dec 17th, 19, 03:40 PM Thread Starter
Steven
stamatisg1977's Avatar
In relation to each other. I have drive by wire ls pedal. Brake pedal has stock disc/disc master
Clutch is the mcleod hyd conversion kit that comes with pedal that has correct pivot point for the rod
Do the clitch and brake pedal need to be the same height or is the brake pedal supposed to be a little lower or vice versa?
Sent from my iPhone using Tapatalk
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 10 (permalink) Old Dec 17th, 19, 04:47 PM
Re: Clutch/brake/acc pedal height
I prefer the brake pedal to be higher than the gas pedal for safety.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 10 (permalink) Old Dec 17th, 19, 04:53 PM
Vega$69's Avatar
The brake pedal should always be higher than the go pedal.
Clutch to brake. Whatever works for you.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 10 (permalink) Old Dec 17th, 19, 06:21 PM Thread Starter
Steven
so what i have looks good?
Tremec TKO 600
post #5 of 10 (permalink) Old Dec 17th, 19, 06:30 PM
Looks good to me but gas pedal looks pretty close to the tunnel. Is there room for carpet and insulation?
dhutton is offline
post #6 of 10 (permalink) Old Dec 17th, 19, 06:42 PM
Tim
Looks very close to mine. I used my factory clutch pedal with a Wilwood conversion and didn't really have to change much of anything other than making sure the pushrod traveled in a straight line. I believe my clutch and brake pedal are the same height. I can post a picture if you think it will help.
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #7 of 10 (permalink) Old Dec 17th, 19, 08:28 PM Thread Starter
Steven
Thanks don
This is the only other pic i took of the pedals. My bracket does let le move it over to the left about 1/4 or so
Tremec TKO 600
post #8 of 10 (permalink) Old Dec 18th, 19, 03:29 AM
Looks like enough room in that pic.
dhutton is offline
post #9 of 10 (permalink) Old Dec 18th, 19, 07:04 AM
Apprentice
Greg
What mount and pedal is that?
thewgp is offline
post #10 of 10 (permalink) Old Dec 18th, 19, 04:55 PM Thread Starter
Steven
detroit speed
https://www.detroitspeed.com/engine-...74-nova-060111
Tremec TKO 600
