TKO 600 Bell Housing Run Out - Team Camaro Tech
 1Likes
post #1 of 20 (permalink) Old Mar 22nd, 20, 05:40 PM Thread Starter
Tim
I am about ready to pull out my hair. Bolted up the flywheel and 621 bell housing to my LS3. Used a Summit Racing dial indicator to measure runout and was way off - about 22 thousandths. Spoke with Gene at SST and he said they have yet to sell a bell housing that didn't work right out of the gate so they sent me another (which I thought was very good of them). Mounted it up and had even more variance regardless of how I fiddled with the dial indicator. I am beginning to think no matter how I tinker with the arrangement of the indicator I can't really get the probe to be at 90 degrees so I am thinking there is deflection working as well.
I am now thinking it is tool failure rather than bell housing. New GMPP engine, new flywheel, new bell housing (2nd) and still not even close on run out. I can't seem to find the kind of indicators everyone uses in videos (round base, very compact) so just wondering what the other guys on the forum have used and where they got theirs. Maybe its just user error in which case that's a whole other ball of wax.
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #2 of 20 (permalink) Old Mar 22nd, 20, 05:52 PM
Vega$69's Avatar
Re: TKO 600 Bell Housing Run Out
Iíve use several SST 621s. Bolted up and weíre good out of the box.
Guessing maybe measuring technique is suspect?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 20 (permalink) Old Mar 22nd, 20, 05:59 PM Thread Starter
Tim
Almost without a doubt John. I am half tempted just to roll with it and call it good. I just can't seem to even duplicate readings if I readjust the indicator so thinking tool and operator error combined. Just a little paranoid considering all the warnings out there and the expense of the TKO.
post #4 of 20 (permalink) Old Mar 22nd, 20, 06:12 PM
Brett
I have the set up you need....give me a minute and I'll get back to you...
Problem is, they will not honor the warranty unless you have proof it was within spec.
Brett....
Rockets Up In 2020!
Brettallen59 is offline
post #5 of 20 (permalink) Old Mar 22nd, 20, 06:24 PM
Apprentice
I'm in the process of installing my TKO 600 from SST and also using the 621 bell housing. I measured my TIR (total indicated runout) and it was within specs, no adjustment needed. I'm converting from a power glide, so I bought the whole kit from them. I've called them multiple times with questions or to get confirmation on various things and I have to say they are incredible to work with. The best customer service experience I've had with any company.
Richmond, VA
Daddio65 is offline
post #6 of 20 (permalink) Old Mar 22nd, 20, 06:27 PM
Brett
This is the one I used. The problem is if you don't have a sturdy, rigid setup, gravity will pull on the indicator giving you a false reading. I've been a machinist for over 40 years and many times there were people that didn't believe gravity affected the readings and its astonishing just how much it does when you show someone.
My TK0600 bell housing was off .015". I purchased offset dowel pins and was able to get it within spec (less than .003")
Mini Mag Indicator Base
Then you need an indicator like this one. It doesn't have to be this expensive, just this type/style; Mitutoyo Indicator
Make sure everything is TIGHT.
I purchased from SST also and it was a great purchase.
Brett......
350sshugger likes this.
Rockets Up In 2020!
post #7 of 20 (permalink) Old Mar 22nd, 20, 06:28 PM
Matt
If you canít repeat the measurement thatís telling you tool error. Most likely the mounting point of the indicator isnít sturdy enough and moving just slightly. Weíre talking about the thickness of a sheet of paper so you wonít be able to see it move by eye. Good practice is to set up the indicator at ď0Ē and then lightly finger tap the mounting linkage to check for rigidity. The needle should barely deflect and return to ď0Ē. I used a magnetic base and was able to get it.
My Build Thread
350sshugger is online now
post #8 of 20 (permalink) Old Mar 22nd, 20, 06:28 PM
Vega$69's Avatar
X2. Iíve used SST many times and the CS is better than any other co I deal with.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #9 of 20 (permalink) Old Mar 22nd, 20, 06:39 PM
Steven
stamatisg1977's Avatar
Got a runout indicator tool on ebay. The post went thru the center of the crank and bolted to one of the flywheel bolts Click image for larger version
ID:	233621Click image for larger version
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #10 of 20 (permalink) Old Mar 22nd, 20, 06:44 PM Thread Starter
Tim
Brett......
Thanks Brett, really appreciate the reply. What's amazing is I searched ebay for that exact base and couldn't locate it.
post #11 of 20 (permalink) Old Mar 22nd, 20, 06:44 PM Thread Starter
Tim
Originally Posted by stamatisg1977 View Post
Got a runout indicator tool on ebay. The post went thru the center of the crank and bolted to one of the flywheel bolts Attachment 233621Attachment 233619
I will take a look at this as well. Thanks for the response and help!
post #12 of 20 (permalink) Old Mar 22nd, 20, 06:50 PM Thread Starter
Tim
I hope nobody thinks I was knocking SST, they have been great. Really an excellent company to work with and I have had dialogue with both Gene and Jack and they are great. This is only frustrating because I am sure it is correct but I can't validate, so it is ticking me off. And since I am probably going to have nowhere to go for the next couple of weeks may as well get this engine and tranny in!!
post #13 of 20 (permalink) Old Mar 22nd, 20, 07:12 PM
I also have a 621 with a measured runout of .022. I use it as a setup mule.
3d cad is offline
post #14 of 20 (permalink) Old Mar 22nd, 20, 07:20 PM
Brett
Tim, I didn't take it as a knock. I took it as a possible "Operator/tool error" tick-off, lol. If eBay shuts down and you don't get the stuff delivered in time, let me know. I still have the tools and I can send them to you. Just hope the United States Postal Service stays open.
The "Bell housing Indicator tool" is nice, but I think they are pretty expensive. If not, it would work pretty good too.
Brett......
Rockets Up In 2020!
post #15 of 20 (permalink) Old Mar 22nd, 20, 07:20 PM
keith
X-77 keith's Avatar
I got my base from harbor freight. I also got a digital dial indicator. Was easy to use and set up. I did a thread on this site on my TKO install. It was about a year and a half ago. I posted pictures, and Gene gave me the go ahead to install.
X-77 keith
X-77 keith is online now
