Converting to a reverse flow cooling system - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 3 (permalink) Old Mar 25th, 02, 06:06 AM Thread Starter
I was wondering if it is possible to use the heads and water pump from an LT1 on a standard Chev 350 block to create a reverse flow cooling system. I guess I don't know much about the LT1 block and would like to know of the differences. Any info would be greatly appreciated!
andyjk1 is offline
post #2 of 3 (permalink) Old Mar 25th, 02, 07:26 AM
anything is possible, but why not just get the LT1 block and use all the factory engineering? from what i understand, all the passages are different, but the heads will physically "bolt on".
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #3 of 3 (permalink) Old Mar 25th, 02, 08:56 AM
Why? The system will be inferior to the one that it was originally designed for.
STEVE JACK
ConceptOne Pulleys and Brackets
HOTRODSRJ is offline
