2600 stall converter in TH350 - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 5 (permalink) Old Mar 27th, 02, 02:40 PM Thread Starter
Does anyone know if a 2400 to 2600 rpm 10" stall converter will damage a used TH350 that has a shift kit. I don't know what how many miles are on the tranny or if it was rebuilt, but right now with the stock converter it works perfectly fine. I plan to run the car on the street and already have a perma-cool tranny cooler.
porcam is offline
post #2 of 5 (permalink) Old Mar 27th, 02, 02:53 PM
If the tranny is in decent shape, it will be fine. Changing the fluid and filter would be a good idea also. Of course, if the tranny is on its last legs the convertor will only help kill it quicker.
travis is offline
post #3 of 5 (permalink) Old Mar 27th, 02, 02:55 PM
Hey, no a stall converter will not hurt a old tranny that has not been rebuilt.my firend put a 3500 in an older th350 and ran it for 2 years, but why spend 250-300 bucks on a converter when for the same money get a good rebuild with a shift kit, i just dropped off a th400 to get rebuilt with a transgo shift kit that you can shift manualy, and or put it in drive and shift on its own, and it will be 300.00, i won't get a converter,(cause i will buy a stall converter)generally a th400 rebuilt with converter is 400- 450 so minus the converter and that will be the price. but if you wanna try it go ahead, and hope you have better luck than me
Jake
BBCamaro is offline
post #4 of 5 (permalink) Old Mar 28th, 02, 12:09 AM
Bruce
I wouldn't be afraid to run it. I ran a 2500 stall in a turbo 350 for years, with a b&m shiftkit. Do like Travis said and give it fresh fluid and a filter and you should be fine. Also it's a good idea, when you have the tranny out to replace the rear tailshaft seal, and also, put in a new o-ring around the dip stick.
Is Bambergers still in business over there in Lebanon? I used to work for them over in E-town, years ago.
Bruce
bruce69camaro is offline
post #5 of 5 (permalink) Old Mar 28th, 02, 04:49 PM Thread Starter
Bruce,
Yea, they're still in business. Thanks for your input.
porcam is offline
