Fuse - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 7 (permalink) Old Apr 9th, 02, 02:34 AM Thread Starter
I had a cd player installed in my car. Now my fuse keeps blowing out. Could it be that some wires are touching, or something like that?
My1stCamaro is offline
post #2 of 7 (permalink) Old Apr 9th, 02, 02:38 AM
yes, i did the same thing in my car and and blew 3 fuses before i found the wires were touching. just pust electrical tape around the exposed wires and you should be fine
ramlet is offline
post #3 of 7 (permalink) Old Apr 9th, 02, 03:38 AM
TOM
You may needa heavier amp fuse to carry to added load of the cd player.
Just try a higher rated one, but don't go too high , or you'll defeat the safety factor of a fuse.
http://hobbystage.net/camaro/tomstv
TOMSTV is offline
post #4 of 7 (permalink) Old Apr 9th, 02, 05:26 AM
Check the cd player documentation to find out what the power requirements are before swapping fuses. You may find that you require a complete new circuit with a fusible link, which is probably the way you should go anyway to ensure that the original wire/fuse combination is not overloaded. Such a condition can cause a fire.
Jim McGregor is offline
post #5 of 7 (permalink) Old Apr 9th, 02, 11:22 AM
JLD
I'd check to make sure its grounded properly. Had the same problem with fuses, turned out it was as simple as being grounded wrong.
JLD is offline
post #6 of 7 (permalink) Old Apr 9th, 02, 06:54 PM
Jim is right. For most new stereo stuff, it is best to be on the safe side and wire it seperately. I reccomend running a 8 guage wire into the passenger compartment and mount an accesory fuse block. This allows you to wire up all kinds of aftermarket accesories(guages, etc.) without overloading the factory harness. Plus, it makes them all removable at a later time. Save a lot of hassle and makes thing real clean.
67 Pro-touring Camaro-327, 9:1, Comp XE268 Cam, Perf. RPM Intake. 750 Holley, Sportsman II Heads, Ceramic coated headers, 700R4 trans, 17" Amer. Racing TT2's, 12" disc brakes, custom stereo, black with white stripes, cowl ind. hood.
Dans67 is offline
post #7 of 7 (permalink) Old Apr 10th, 02, 06:05 AM
Heavier fuse? as a firefighter of 20 years ...can you say car fire?
This is so much fun I can't believe it's legal.
www.chevelles.com/showroom/birjrm2.jpg
www.chevelles.com/showroom/birjrm1.jpg
Midlife Cruiser is offline
