68 impala in wrecking yard . . . will any parts work in the camaro?? - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 6 (permalink) Old Apr 11th, 02, 09:50 AM Thread Starter
Tim
Some of stuff is gone . . . but it is an AC car with pS and a 327.
What good parts can I get off this car that will work for a 68 camaro??
ratchetmaster
1968 RS SS 350 M4
1969 olds 442 convertible
1972 454 ElCamino Turbo 400
1973 RS LT Z28 Camaro M4
1995 Caprice LT-1 WWW A4
1999 Firebird WS-6 T/A A4
moderator http://www.gmforums.com
[This message has been edited by ratchetmaster (edited 04-11-2002).]
ratchetmaster is offline
post #2 of 6 (permalink) Old Apr 11th, 02, 11:26 AM
Vintage 68's Avatar
Maybe;
Horns!
Engine and trans of course
Crossmember for other projects?
Aircleaner
Drums, backing plates and other brake hardware for upgrades.
Interior parts, Seat Belts?, door hardware, handles, Dash parts, instrument lights, glove box parts, etc...
Lamp connectors and wiring parts.
Lots of different fasteners, bolts, cage nuts etc... save them all!
Frame parts, fuel & brake line clips etc...
Start at the left front and go all the way around, in, under and over the car looking at all the little bits and pieces - remove and mark as you go. (if you mark everything you will remember what it is, where it came from and know where to get one next time you need it).
I have been amazed at the parts I've found to use later on my cars and trucks.
Lastly - let us all know what you found that you knew you could use, good info for us all!
Vintage 68 is offline
post #3 of 6 (permalink) Old Apr 11th, 02, 11:55 AM
Some 68 full sized Chevy's had the 4 piston calipers on front if they were disc brakes. A 68 SS Impala, also a 327 car donated a 12 bolt which I'm having shortened and putting spring perches on for a 67 Nova project.
SolidLifters is offline
post #4 of 6 (permalink) Old Apr 12th, 02, 11:10 AM Thread Starter
Tim
thanks guys . . .
I will definitely check the front calipers . . .
what about interior stuff . . . ac controls, ac box, other engine compartments stuff??
post #5 of 6 (permalink) Old Apr 12th, 02, 11:52 AM
Chris
If it has hideaway lights it uses some of the same vacuum stuff.
'69 RS SS 396 375hp L78 Convertible, M22, 3.31 posi, deluxe interior, gauges, rosewood wheel, AM-FM, fold down seat, tilt wheel, Torque Thrust Wheels, console mounted 8 track player, chambered exhaust, locking gas cap
COMING SOON Corvette tripower, small body HEI, and maybe "842" aluminum heads
Chris396 is offline
post #6 of 6 (permalink) Old Apr 12th, 02, 02:47 PM
Freddie
If it has a 12 bolt rear end, get it. It can be narrowed and used in a Camaro or Nova.
'69 RS/SS396 pro street
427/4spd/9"
Byars Performance
High Performance Drive Train Parts And Service
www.lubedealer.com/biggearhead
big gear head is offline
