4-speed shift tunnel, non-console - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 10 (permalink) Old Apr 13th, 02, 03:08 AM Thread Starter
resto4u's Avatar
Are shift tunnels different for 67 and 68 with four speed? Is the hole the same weather you have a console or not? Here is the problem. I have a 67 4 speed with no console. I just bought a shift plate retainer, and it does not look right. Will not sit on the tunnel over the hole right.Looks like the hole is too far to the driverside.The shift plate would have to be bent down where the tunnel curves down. Anyone have pics of a 67 non-console tunnel and shift plate retainer? Thanks,Roger
resto4u is offline
post #2 of 10 (permalink) Old Apr 13th, 02, 08:24 AM
Sounds like someone manufactured the shift hole themselves. The correct hole is a clean cut with a reinforcement spot welded around it from the underside, unlike the 69 4-speed hole. My 67 is an original 4-speed without console and the shift hole, although not perfectly centered on the tunnel, does not even come close to the edge of the tunnel where it curves downward. All 67's with floorshift auto or manual transmissions have the identical hole in the tunnel. The 68 uses the same configuration but for MANUAL transmissions only. Automatics in 68 used a cable shift eliminating the need for a large hole. If need be, I will photo my shifter. The carpet is removed already.
1967 Panther is offline
post #3 of 10 (permalink) Old Apr 13th, 02, 09:23 AM
Denis
The reinforcement on the underside of the shifter opening is shown pretty clearly in the center photo of the 'collage' below.
deejaygee is offline
post #4 of 10 (permalink) Old Apr 13th, 02, 09:31 AM Thread Starter
resto4u's Avatar
panther, could you send me the pic of the shift hole and shift plate retainer.Does yours have a stamping of LTC on the top? It has the original shift hole and plate spot welded underneath. Either the shift hole was messed up at factory, not centered very well. Or the shift plate retainer is not the right one.In the assembly manual on page 316. The retainer 3893854, mine looks different than pic. Thanks,Roger
resto4u is offline
post #5 of 10 (permalink) Old Apr 13th, 02, 09:36 AM Thread Starter
resto4u's Avatar
Hi denis, nice pics. your car is looking great. If i see a pic of the retainer, i will know if i have the right part. Thanks,Roger
resto4u is offline
post #6 of 10 (permalink) Old Apr 13th, 02, 03:08 PM
Roger, the retainer in the assembly manual looks just like mine. I don't think the factory messed up yours, I think you have the wrong retainer. It should be a rectangle with one side slanted a bit.
post #7 of 10 (permalink) Old Apr 13th, 02, 09:54 PM
Denis
Roger, I wish that was my car. Those are photos of a crossram 67 Z28, restored by Dave Tinnel in Kentucky, that belonged at the time to Charley Lillard (clill on this site). Here's a picture of my shifter hole from not that long ago:
[This message has been edited by deejaygee (edited 04-14-2002).]
post #8 of 10 (permalink) Old Apr 14th, 02, 02:33 AM Thread Starter
resto4u's Avatar
I must have the wrong shift plate retainer them. The one i just bought is square and not reqtangular like the shift hole. It also has 4 bent tabs to attach the shift plate, but there are two on each side and non on front or back of retainer. Does not look like the pic in the assembly manual. My shift hole is not as well centered as yours denis. I have a shift plate coming, and if it doesn't match the retainer then i know for sure. Thanks,Roger
resto4u is offline
post #9 of 10 (permalink) Old Apr 14th, 02, 02:38 AM Thread Starter
resto4u's Avatar
I must have the wrong retainer, mine is square. Not reqtangular like the sift hole. The bent tabs are not right place either. Thanks, Roger
resto4u is offline
post #10 of 10 (permalink) Old Apr 14th, 02, 09:03 AM
You may have one for a 70-up Camaro...they were square.
