Cylinder Head Clearance question?? - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 4 (permalink) Old Apr 16th, 02, 02:20 PM Thread Starter
I am going to be changing heads soon..I want to go with 64cc heads with 206/190 valves...The original builder of the engine tells me he ran KB domed pistons with valve reliefs..The builder states that the KB setup recomended 64cc heads to acheive a 10-7-3 compression..But when the cam was changed so was the were the heads to 76cc...Do you guys think I am going to have clearance issues if I go back to 64cc..Would running the KB domes with 64cc heads and a 5.15 lift on the cam..Be to much..Thanks in advance
Badcaiman is offline
post #2 of 4 (permalink) Old Apr 16th, 02, 07:24 PM
Everything I know about small blocks tells me with a 64cc head and flat tops you get around 10:1 compression. I'm running 58cc bowtie heads with flats and getting about 10.8:1. With a .100 dome and a 64cc head in a 350 you're looking at about 11.5:1, a liitle less in a 327 and a little more in a 400. If you're planning on running pump gas stick with the bigger heads.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #3 of 4 (permalink) Old Apr 16th, 02, 10:45 PM
In my opinion, duration is as important as lift when it comes to piston to valve clearance. Maybe more so.
You could always mock it up with the new heads to make sure you have enough clearance.
Toby Keen is offline
post #4 of 4 (permalink) Old Apr 17th, 02, 02:43 PM
I run 64cc heads with '69 Z28 domed pistons and a .524" lift, 254 degrees duration camshaft. The only way to be sure is to bolt the heads up and do a valve drop 10 degrees before and after TDC. I had plenty of piston-to-valve clearance, but the modern combustion chamber shape required a short spark plug to keep from hitting the piston domes.
NeilB is offline
