Big Cam Idle question?? - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 9 (permalink) Old Apr 19th, 02, 04:56 PM Thread Starter
I am running a lunati #12 cam([email protected] Duration and 515 lift)I can't seem to get a good idle under 1000rpm(7" of vacuum)..Would you guys say this is reasonable..I can get it to idle at 800rpm but the thing shakes way to much and I only pull 4"of vacuum...
So do you guys think 1000 rpm idle is exceptable for this big of a cam..Thanks
Badcaiman is offline
post #2 of 9 (permalink) Old Apr 19th, 02, 06:18 PM
If you're using a Holley, what power valve are you using?
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #3 of 9 (permalink) Old Apr 20th, 02, 03:01 AM Thread Starter
I'm running a edelbrock(600cfm)on a original torker intake...
post #4 of 9 (permalink) Old Apr 20th, 02, 06:34 AM
How much initial advance on the timing?
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #5 of 9 (permalink) Old Apr 20th, 02, 06:49 AM
Call me Funk
Send a message via AIM to CFunK
What color step up spring you running in the Edelbrock?
-Funk
CFunK is offline
post #6 of 9 (permalink) Old Apr 20th, 02, 08:47 AM Thread Starter
I am running approx 18*advanced and for the springs I believe they are stock...Thank you...
Anyone else running the same cam..Thanks
post #7 of 9 (permalink) Old Apr 20th, 02, 12:38 PM
JohnZ's Avatar
1000 rpm and 7" is probably as good as you're going to get with that much cam; you can't have a huge cam with big-time overlap and lift and expect it to idle anywhere near normally.
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
post #8 of 9 (permalink) Old Apr 20th, 02, 02:36 PM
Eric
I would try connecting the vacuum advance to a manifold source - more timing at idle seems to help big cammed engines idle better. I like the ported source though for my engine since it has a more "reasonable" 236* duration cam.
I wouldn't expect it to idle much less than 1000 RPM though.
Eric68 is offline
post #9 of 9 (permalink) Old Apr 20th, 02, 03:00 PM Thread Starter
I am running manifold vacuum now for my advance..I guess you guys are right..It idles better than I expected at 1000rpm but wanted to check with you guys...I know I have to change the metering rod springs like some of you guys have suggested..Since I do have alittle dribble from the primaries at idle...and it starts to load up at idle on occasions....Thanks for the advice guys..I really appreciate it
