rodents - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 23 (permalink) Old Apr 28th, 02, 12:06 PM Thread Starter
thewebb1's Avatar
Not really a car question but its for my workshop that holds the car.
I'm reinsulating the shop and want to know if anybody has found a way to rodent proof their shop. The mice and moles are having a great time eating and breeding in the old insulation.It has a concrete floor and 2x4 walls with board and batten outside.They get in where the floor and wall meet mostly but I've found nests as high up as 8ft.The only thing I can think of is to put concrete blocks all the way around but that would be a lot of work and expense. Any thoughts?
68 Camaro Coupe(restoring)
65 Pontiac Parisienne Convertible Summer Cruiser(Canadian version of Bonneville)
thewebb1 is offline
post #2 of 23 (permalink) Old Apr 28th, 02, 12:23 PM
click's Avatar
There must be small cracks or holes allowing them into the walls from outside, so try that expanding foam in a can to plug the holes. Use it along the whole outside edges of your siding where it meets the block. There are 2 kinds, regular and mild expanding type. The regular can really push out against the walls while expanding, use the MILD type, wear throw away gloves, and you can cut off any excess that shows after its done curing.
Then get a cat for inside declawed of course so it doesnt scratch you car up.
click
69RS 350/255 LM1,TH350,Dover White,Blue Vinyl top
F&R spoilers,pdb,ps,am/fm,4.10 Posi.,A/C,
fold down rear seat.
My RS www.brainerd.net/~knudsen/69RS
click is offline
post #3 of 23 (permalink) Old Apr 28th, 02, 12:34 PM Thread Starter
thewebb1's Avatar
Hi Click
I thought about the foam but figured they would just chew thru it.The cat's a good idea but it's IN the walls thats messing up my insulation.I just got rid of the squirrel smell from inside the Camaro.With my luck the cat would leave its mark there too. Any other thoughts?
thewebb1 is offline
post #4 of 23 (permalink) Old Apr 28th, 02, 02:02 PM
I use decon rat/mouse poison now with good success. Nasty things were nesting under the back seat of my "rat" infested Camaro!
Turbo_Jet is offline
post #5 of 23 (permalink) Old Apr 28th, 02, 03:12 PM
Feed all of the local cats it works better than anything. I haven't had any problems in years.
oger is offline
post #6 of 23 (permalink) Old Apr 28th, 02, 05:17 PM
The only thing mice can't chew through is metal and concrete. Use steel wool or sheet metal to fill all holes and cracks. Use some metal flashing at the seam where the wall meets the floor. Then set a bunch of traps and kill any little *(*&^**( that make it through your fortress!
My garage is well sealed and I still set traps constanly just to make sure I don't have any unwanted passengers in my car.
'67 Z-28 Network: www3.sympatico.ca/67z28owner/index.html
2002 Quicksilver Corvette Z06
Looking for '67 Z-28
Zedder is offline
post #7 of 23 (permalink) Old Apr 28th, 02, 05:28 PM
stevo camaro's Avatar
Did you guy's know a good size rat can squeeze thru a 1/4" wide crack. Field mice too. (Mom owns a pest control bussiness.) I use poisen & sticky traps. I'll never get the shop sealed good enough. I had a rat problem, took the interior completely out of race car. They're gone now. I've got the poisen laying around and I've seen nothing for awhile now.
67 396 race car project
67 SS 396,4-sp mothballed for resto
67 RS 327,4-sp
72 RS 350/350, under current resto
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
stevo camaro is offline
post #8 of 23 (permalink) Old Apr 28th, 02, 06:16 PM
xodus921
Guest
Posts: n/a
I made a pet out of my little friend...I use to try and feed him. The only thing in my garage was tools though. He use to come out and sit under the car with me while I was working on it. Friendly little guy...I don't think he made it through the winter though.
Tony
<UL TYPE=SQUARE>
<LI>1979 Z-28, 350- Edelbrock Performer RPM cam and intake, Holley 650, Trick flow twisted wedge heads, dynomax headers - TH350[/list]
post #9 of 23 (permalink) Old Apr 29th, 02, 03:31 AM
Rick
Living on a horse farm, I see my share of critters. The only real solution is traps/poison, I'm afraid. With dogs/etc. we got pait traps from an exterminator since we didn't want poison around where the pets could get at it.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
RickD is offline
post #10 of 23 (permalink) Old Apr 29th, 02, 04:12 AM
those sticky things that are flat work great! they walk on them and cant get off. They just starve to death. Lay them around the garage. Theyll fill up quick then just throw them out.I actually had mice in my firewall that built nests and man was that a trip to clean out! jim
http://community.webtv.net/james778/our1969camaro
bakerdude is offline
post #11 of 23 (permalink) Old Apr 29th, 02, 08:45 AM Thread Starter
thewebb1's Avatar
Thanks people. No cure but greats stories and laughs.I wouldn't mind the little rascals if it wasn't for the damage to my insulation. Heating a workshop is not cheap! Stevo Camaro-I was thinking of wire mesh which measures 1/4"x1/4" ask your Mom if that would work.I also thought of aluminum flashing at top and bottom with the wire mesh in between.
Tony-you are spending way to much time alone in your shop.Sorry about your loss .RickD- I live on a horse farm also.Got lots of barn cats but no shop cats but its inside the walls anyways.Keep those suggestions coming.
thewebb1 is offline
post #12 of 23 (permalink) Old Apr 29th, 02, 09:50 AM
Robert
I like to use the little square green colored rat bait poison. You can tell when they have been eating it and then when they're gone no more nibble marks on the bait.
Tony, your friendís name wasn't Ben was it?
Robert Johnson
'69 getting better every day... (every pay day)
350ci 700r4 3.55 posi
rojo is offline
post #13 of 23 (permalink) Old Apr 29th, 02, 01:35 PM
I have a concrete block garage ruffly 20'X 20', with rafters at 8' of the floor, and no insulation.
Those little suckers were in the rafters!
How ??? were up in some parts boxes I had there.
I used those sticky traps, worked GREAT, especially when you put a small piece of food on them!
I still have a couple up there still. I check from time to time. Haven't seen any since!
Roger
68Datona is offline
post #14 of 23 (permalink) Old Apr 30th, 02, 06:12 PM
Rojo, your dating yourself. The movie Ben, I haven't seen that in awhile.
Thewebb1, You almost have to be air tight to keep them out. I'll tell ya how they got in the 67. The window felt was missing on both rear quarter windows & the door panels were gone. That's all they needed to get in.
67 RS 327,4-sp
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
post #15 of 23 (permalink) Old Apr 30th, 02, 09:22 PM
xodus921
Guest
Posts: n/a
I'll have to check that movie out...No I never named him.
