General Restoration Thoughts - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 13 (permalink) Old May 3rd, 02, 10:11 AM Thread Starter
I'm wondering what most guys feel about using SS lines (fuel/brake) instead of std replacement. I'm getting my car cose to stock and want to replace some lines. Do you consider a car "way wrong" w/ ss lines? Thanks, John
69DZ is offline
post #2 of 13 (permalink) Old May 3rd, 02, 10:50 AM
Only a real purist would turn their nose up at something that I think looks better and lasts longer. My 2 cents.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #3 of 13 (permalink) Old May 3rd, 02, 11:28 AM
I think it all depends on what you want the car to be. If you want it to be 100% stock then don't use S/S lines or hoses. If you just want it to look "pretty original" then you can get away with non-OEM parts like lines and hose clamps etc..
As for purists, there are a lot more of us out there than you think. To me, putting a S/S brake line in my car would be no different than putting Fiero seats in it. It would never cross my mind to do either.
My $.02
Scott.
newport30 is offline
post #4 of 13 (permalink) Old May 3rd, 02, 11:28 AM
Gene
That's what purists are good at though.
Seriously, I would go stainless. You might want to try and scuff up the tubing a little so it is not as shiny - regular steel tubing is a little grayer and not as shiney. Maybe use steel wool.
gheatly is offline
post #5 of 13 (permalink) Old May 3rd, 02, 11:47 AM
I've heard a number of people having problems with stainless lines leaking at the fittings.
69 BMotion is offline
post #6 of 13 (permalink) Old May 3rd, 02, 12:00 PM
ZZ_430's Avatar
I agree...go stainless!
Sure, it's harder to work with and flare, that's where some people have problems with leaks..
Technology moves on!..
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
67 RS/SS Convertible, 70 RS/Z28
[This message has been edited by ZZ430DropTop67RS (edited 05-03-2002).]
ZZ_430 is offline
post #7 of 13 (permalink) Old May 3rd, 02, 02:10 PM Thread Starter
Thank you for the comments. I knew there would be opposing thoughts on this because it is kinda a fine line in my opinion, I am just so happy to have my car "close" now! Thanks to all of you, John
69DZ is offline
post #8 of 13 (permalink) Old May 3rd, 02, 02:12 PM
I agree with the stainless leaking at the fittings. There was a thread over a year ago here where a number of folks had that exact problem.
Silver69 is offline
post #9 of 13 (permalink) Old May 3rd, 02, 02:20 PM
Rick
I have had to replace both my brake lines and gas line. I considered ss but got OE instead. Primarily because to me it was overkill ( not that I don't get carried away too ). Personal choices.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
RickD is offline
post #10 of 13 (permalink) Old May 3rd, 02, 04:23 PM
Stainless steel is very hard by nature and doesn't conform very well to imperfections in mating surfaces. Unless you want heartache don't use it unless you really have to. Wes
MY396 is offline
post #11 of 13 (permalink) Old May 3rd, 02, 06:26 PM
I've got stainless lines for brakes and fuel. I got it because I felt it would last longer. I agree about problems with leaks though, I dred anytime I have to loosen a line for something. When I tighten them up, I have to really wrench on them so they don't leak. Good thing I have line wrenches, or I'd have a bunch of stripped out fittings.
68BB427 is offline
post #12 of 13 (permalink) Old May 4th, 02, 08:52 AM
I look at it like this..if the original non-stainless lasted 35 years, that's long enough for me...Forget the stainless, go original!
1967 Panther is offline
post #13 of 13 (permalink) Old May 5th, 02, 11:11 AM
Bruno
<BLOCKQUOTE>quote:</font><HR>I look at it like this..if the original non-stainless lasted 35 years, that's long enough for me...Forget the stainless, go original!<HR></BLOCKQUOTE>
I tend to share the above mentioned thinking.
Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench
ORENCH is offline
