frustrated with 94 Z28 - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 11 (permalink) Old May 12th, 02, 04:43 PM Thread Starter
Could someone tell me how in the Heck you get the no. 4 plug back in a 94 Z-28. I got 6 plugs in with not much trouble, the no. 8 plug seems to be impossible so I left it alone. I got the no. 4 out with alot of trouble. I thought I could put the new one in but theres no way! I have worked on the one plug for 6 hours! I removed the alternator, but still cant get the plug started in the hole. I dont have much patience or skin on my arms left. Any suggestions would be appreciated. If I get through this, I am going to stick to working on my 69!
yogi is offline
post #2 of 11 (permalink) Old May 12th, 02, 04:56 PM
mccorry's Avatar
to get #8, grease up your forearm and slide it down between the manifold and strut tower. With your other hand, slip down the wrench... that is how I got to mine.
Steve - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> My Camaros (updated 3/7/02)
mccorry is offline
post #3 of 11 (permalink) Old May 12th, 02, 05:02 PM Thread Starter
Thanks. Any suggestions on getting the no. 4 in?
yogi is offline
post #4 of 11 (permalink) Old May 12th, 02, 05:07 PM
ZZ_430's Avatar
Have you tried putting a length of vacuum tubing over the plug terminal, then "fishing" down in place.
With the tubing tight on the plug, it's very easy to spin for starting in the hole.
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
67 RS/SS Convertible, 70 RS/Z28
[This message has been edited by ZZ430DropTop67RS (edited 05-12-2002).]
ZZ_430 is offline
post #5 of 11 (permalink) Old May 12th, 02, 05:16 PM
Send a message via AIM to CamaroNOTcamero
grease up and get creative! good luck to ya.
CamaroNOTcamero is offline
post #6 of 11 (permalink) Old May 13th, 02, 09:27 AM
Ron
For number 4, Slide the plug into a real spark plug socket, the kind with the hex head on it. You can then use your finger tips to get it started and use a box end wrench to tighten it up.
For number eight I removed the starter and did it from underneath.
Good luck.
Ron
70 Chevelle SS396 (427)M21 Before / After
66 Nova SS 327 M20
95 Z28 Convertible T56
Aces 3081, TC #54 Gold
ToocoolZ28 is offline
post #7 of 11 (permalink) Old May 13th, 02, 11:11 AM Thread Starter
Thanks for all suggestions. I have tried a few already, but for some reason they stuck every hose and metal pipe they could, right where you need to get your hand. I am going out now to see if I can get it in. I hope since it is a new day, I will be able start fresh.
yogi is offline
post #8 of 11 (permalink) Old May 13th, 02, 03:47 PM Thread Starter
5 more hours and still cant get that #4 plug started. I have tried everything. I guess I will have to find someone with smaller arms and longer fingers. I have built a 55 chevy, a 56 chevy, and I just finished a 69 rs-ss, and I cant even put a spark plug in this "modern" car. Its embarrassing! Any more sugesstions will be appreciated. Thanks.
yogi is offline
post #9 of 11 (permalink) Old May 13th, 02, 05:55 PM
Call me Funk
Send a message via AIM to CFunK
The plugs on an LT1 are a bitch. If you have a skinny friend I'd ask them to have a go at it. I did all 8 my my 97 TA and remember it being a real bear to do.
-Funk (Skinny arms and long fingers dude)
CFunK is offline
post #10 of 11 (permalink) Old May 14th, 02, 03:42 PM Thread Starter
I finally got it! I actually made a mistake in posting this, it was the no. 2 plug that I was having trouble getting back in, not the no. 4 as I stated. I wont even try changing no. 8, untill I get over the stress of no. 2. Thanks for all the help. I put in 100,000 mile plugs and you can bet this car will never see another plug change as long as I own it!!!
yogi is offline
post #11 of 11 (permalink) Old May 15th, 02, 04:53 AM
Jeff
I'm not sure why you had so much trouble with the No 2 plug, maybe the 94 is different but on my 93 I had it changed out in less than 5 minutes without removing anything. As for # 8, disconnect the battery and move the starter out of the way and reach up to get it. If you still don't have enough room, you might need to drop the y-pipe. I hate to say it, but those 100,000 mile plugs don't survive and you'll need to do it long before that. You should be good for 25-30K miles for now though.
Jeff H - 93 Indy 500 Pace Car driven daily, Hugger Orange 69 Z28, original factory JL8 brakes, cross-ram & GM fiberglass hood, TI setup, heater and radio delete, being restored
Jeff H is offline
