Subframe connectors-WOW - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 17 (permalink) Old May 18th, 02, 08:43 AM Thread Starter
Guy's just wanted to drop a note on these that I just installed. The history is, I pulled the cross brace on my 67 convertable to install the AT exhaust and descided to use subframe connectors instead of lowering the cross brace.
What a difference it has made in the handling amd ride. If you own a convertable three things you really need and may not know are, 1. larger sway bar, 2. multi-leaf springs, and 3. subframe connectors.
BTW I used the Comp Engineering ones and notched them to fit, then box welded them. They are the bolt in kind, I bolted the back and front then welded the front in.
RickB1B is offline
post #2 of 17 (permalink) Old May 18th, 02, 03:58 PM
Chris
ckaram's Avatar
Amen! I've done all three to mine. My connectors are Global West's so I still have my x brace, but the effect is the same. Like a whole new car.
68 Camaro ragtop, original 327, angle plug Camel humps, 202's, Performer, Holley 650 double pumper, Doug Thorley headers, 3-speed Saginaw, 3.08 posi, subframe connectors, Addco sway bar
http://hobbystage.net/camaro/cjkaram/
ckaram is offline
post #3 of 17 (permalink) Old May 19th, 02, 11:18 AM
Randy
rs1968ss's Avatar
I can't find those connectors on Global's website. Do you have any info on them? Cost?
-Randy
Cars:
<A HREF="http://www.camaroclubkc.com/rs1968ss.htm" TARGET=_blank>68 RS/SS BB ragtop
</A>RWHP: 329.4 RWTQ: 398.9
63 Nova II ragtop
Club:
Camaro Club of Kansas City
rs1968ss is offline
post #4 of 17 (permalink) Old May 20th, 02, 04:42 AM
Send a message via AIM to jrager
http://www.globalwest.net/
Last I checked they did not have any information about the convertible connectors on their web site but if you call them you can order them.
If I remember correctly they were around $225. Pricey but I did not have to cut my floor.
69 RS Convertible Camaro, 350/350. Orignal red with black top and interior.
http://www.ragersworld.com/
jrager is offline
post #5 of 17 (permalink) Old May 20th, 02, 06:49 AM
Randy
rs1968ss's Avatar
Thanks. I'll give them a call. Would they interfere with Cal-Tracs? I am thinking about adding them as well.
-Randy
Cars:
63 Nova II ragtop
Club:
rs1968ss is offline
post #6 of 17 (permalink) Old May 22nd, 02, 10:09 AM
Peter
Rick,
I understand multileaf springs create a harsher ride than other alternatives. Are you recommending anything other than monoleafs, or do you like multileafs over all others?
coach420 is offline
post #7 of 17 (permalink) Old May 22nd, 02, 12:21 PM Thread Starter
Yes I have the 5 leafs and the ride is kind of harsh but still acceptable. If I had it to do again I would use the three leaf springs. I had monoleafs before and they bottom'd out on every bump, also the tended to hop with hard accelleration. I think the stiffer monosprings might be ok but I've heard they don't do much for the wheel hop.
RickB1B is offline
post #8 of 17 (permalink) Old May 22nd, 02, 04:13 PM
Chris
ckaram's Avatar
If you get the factory replacements springs for the monoleafs, they'll give you three- leaf springs.
That's what I had done and the ride is not too harsh. Sort of the middle ground...
ckaram is offline
post #9 of 17 (permalink) Old May 23rd, 02, 04:10 AM
Are the convert-sub frame connectors any different from the coupe connectors?
Is there any agreement as to what the favorite sub frame connector is,
- Bolt in?
- Cut and weld in?
Something I've been wondering about. What about a bolt in subframe connector that has a mid flange, or any flange, that gets welded to the floor pan? Something less drastic than cuting the floor up yet provides a three place tie in on the connector vs. front and back.
What do you think? Is there such a thing?
Comments?
Rick O'Loughlin
Scoop69RS-SS is offline
post #10 of 17 (permalink) Old May 23rd, 02, 04:58 AM
Randy
rs1968ss's Avatar
The coupe connectors will not fit on a convert (without modification) due to the convert's floor bracing. Weld-in's are generally preferred.
-Randy
Cars:
63 Nova II ragtop
Club:
rs1968ss is offline
post #11 of 17 (permalink) Old May 23rd, 02, 09:15 AM
I agree. I would think that the weld-ins would be better. I'm looking to see if there is a happy medium between the two. Bolt-ins are easy, weld-ins provide more support. What about a bolt-in that has a couple of tabs that get welded?
This is a huge difference between cutting the floor boards to weld in the DS&E type verses bolts front and back.
What do you think? Input?
I guess it would be just as easy to attach "U" or "L" brackets running from the side of the sub frame connector up to the floor board. Understand, for a novice, it would be easy to tack weld these in.
Rick O
post #12 of 17 (permalink) Old May 23rd, 02, 12:13 PM Thread Starter
Do not cut your floor. There are suframe connectors made for converts, some of the above post talk about them. I got the CE ones and had to notch them to fit. That is a good idea about welding them to the floor I may do that. I know notching them weakens them but I think it's better than nothing. From the ride I know this is true.
As far as bolt in vs weld in I think the bolt in are better, but I bolted the back and welded the front. This is strickly because I'm a novice welder and this was well within my abilities.
RickB1B is offline
post #13 of 17 (permalink) Old May 24th, 02, 01:35 AM
Ken
Rick, how much did you have to notch those CE's? Is it only one spot? I've been thinking about the same thing. I was wondering if instead of notching and removing that piece altogether, what if you bent the notched piece out 90* and used that flange to either bolt or weld onto the K brace it has been notched to get around. I thougt maybe if the K brace is thick enough you could drill and tap for a couple of bolts through each flange. It would be bolted on each end and in the middle and would be easy to remove. (I don't weld at all yet)
Winch is offline
post #14 of 17 (permalink) Old May 24th, 02, 02:23 AM
my CE bolt-ins required no modification. It might have something to do with the body bushings?
boodlefoof is offline
post #15 of 17 (permalink) Old May 24th, 02, 05:01 AM
Ken
Boodle, you don't have a ragtop right? That's what requires the mods.
Winch is offline
