4 speed problems with my 69 z - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 31 (permalink) Old Jun 2nd, 02, 11:19 AM Thread Starter
heres the deal, the 69 I bought in 4000 pieces is now down to about 225 parts. When I installed the motor/trans yesterday, I was installing the shifter/plate assembly and it will not line up with the hole in the floor.It sets back about three inches to far.Upon further inspection, the speedo gear is on the drivers side which means the tail shaft housing is different (believe me, it took a lot of looking at pix and assembly manuals, etc to figure this simple one out)I went to another friends house and looked at his 4 speed with the speedo dump on the passenger side, measured, etc. and the "W" shaped bolt holes measure the same from the rear. Is this piece from a corvette and thus not placing the shifter in the right spot, or have I not got it bolted up inproperly? What a pain in the ford!! HELP!!
By the way, the shifter, the plate, all are from a 69 z-28.
ummgawa is offline
post #2 of 31 (permalink) Old Jun 2nd, 02, 11:25 AM Thread Starter
additional info for above, I measured the length of the trans, it the same.(I'm desperate) There is not a chance that the car was a 3 speed, is there?(I know that all z's were 4 speeds, so don't go there) are the tunnels different for a 4 vs a 3 speed? I'm really reaching here, but I need completion on this fellas.
ummgawa is offline
post #3 of 31 (permalink) Old Jun 2nd, 02, 11:31 AM Thread Starter
I spoke to the last owner, and he told me that when he removed the motor /trans, he dropped the assembly and broke the tail piece and had a trans man rebuild the trans and the dude replaced the tail piece, but he didn't think any thing of it because he never got that far with the restoration. It is a muncie, right numbers for my 69 z.
ummgawa is offline
post #4 of 31 (permalink) Old Jun 2nd, 02, 11:58 AM
Dude, Been there, done that, t-shirt don't fit anymore.
Get the casting number off the tranny tailhousing and we will see if that is the problem. Also, the shifter itself is unique. It has an adjustment fore and aft but start with the tailhousing number. Since the speedo is on the wrong side we can be pretty sure it is the culprit. You might try a different position on the tailshaft?
Do the shifter levers bolt on to the tranny or do they use a stud with a nut?
-Mark.
stingr69 is offline
post #5 of 31 (permalink) Old Jun 2nd, 02, 11:59 AM
joseph l clance
joe clance's Avatar
I converted a three speed to a four speed in 69 camaro and the original shift hole was used successfully. the bigest problem was the shifter itself. had to buy the hurst camaro shifter for 1969 . also the orininal three speed had the speedo cable on the drivers side, while the muncie four speed had the speedo on the passengers side. Went to advanced auto and bought an extension and worked out great. Take a good look at the shifter and make sure it a 69 camaro shifter. if not it probable wont tunnel correctly!
thx
joe c
joe clance is offline
post #6 of 31 (permalink) Old Jun 2nd, 02, 12:11 PM
William
William's Avatar
Your trans was incorrectly rebuilt with a pre '66 tailshaft housing. In addition to the speedo cable location the shifter mounting points also differ. The correct housing for a '69 will have 5, not all are used.
Any trans shop that rebuilds Muncies should have the correct housing.
William is offline
post #7 of 31 (permalink) Old Jun 2nd, 02, 05:15 PM
joseph l clance
joe clance's Avatar
[QUOTE]Originally posted by William:
[B].pre '66 tailshaft housing. .. The correct housing for a '69 will have 5, not all are used.
.I replaced my saginaw three w/ a 1966 m20 that had 5 shifter mount holes (i beleive its the "w" series of holes you refer to in your original post.
If there are 5 mount holes on the drivers side tail shaft it should work and tunnel the shifter to the original shifter cut out. I had a shifter that was not camaro specific and had to purchase the hurst 1969 camaro shifter kit.
hope this helps
joe c
post #8 of 31 (permalink) Old Jun 3rd, 02, 08:30 AM
Gene
I converted my 3 on the floor car to an M-21 and had to enlarge the shifter hole about 2 inches toward the rear of the car. I also used a '69 GM Hurst shifter.
gheatly is offline
post #9 of 31 (permalink) Old Jun 3rd, 02, 04:58 PM Thread Starter
Thanks for all of the advice-any one have a correct tail piece out there? I am in search of as we speak. It quite literally has my other 221 parts on hold as I cannot even mount my console, boot, ring etc until this is resolved. And the having to take the dang trans out again thang!!! I have built this car three times at least doing it wrong the first two times, Can I get a witness? I guess I can say that I have reassembled three 69 z's, all marina blue!!
Thanks again for the help, this site has been the lifesaver for my restoration, as I am a "I like 'em the way the general put 'em together" kinda Dude.
By the way, the shifter is correct the plate is correct(no stud, just bolts) and the tail shaft is incorrect!!
ummgawa is offline
post #10 of 31 (permalink) Old Jun 4th, 02, 02:07 AM
Old Man Engineering has the housing if anybody does. He does high end modified trannys and Long shifters, etc but he also has lots of used parts for reasonable prices. Give him a call. Real nice guy.
He has a web page with a list of parts and prices.
-Mark.
stingr69 is offline
post #11 of 31 (permalink) Old Jun 4th, 02, 12:04 PM
Charley
clill's Avatar
Marina Blue ? Don't tell us you also painted it the wrong color.... Lemans Blue ?
clill is offline
post #12 of 31 (permalink) Old Jun 4th, 02, 12:25 PM Thread Starter
Clill, you're killin me man!
Please allow me to beat myself up...
ummgawa is offline
post #13 of 31 (permalink) Old Jun 5th, 02, 02:26 PM
JohnZ's Avatar
You need a casting #3857584 extension housing with the passenger side speedo gear to make it work; OEM shifter needs the OEM extension housing.
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
post #14 of 31 (permalink) Old Jun 10th, 02, 12:13 PM Thread Starter
Do you have one reasonable?
ummgawa is offline
post #15 of 31 (permalink) Old Jun 11th, 02, 02:48 PM
Ummgawa, you might try Year One(Stone Mountain) or Rick's First Generation(Athens) or a local salvage yard. Most have interchange guides for cars and casting numbers.
Georgia_Gearhead is offline
