Victor Jr Intake and Manifold Vacuum??? - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 3 (permalink) Old Jun 5th, 02, 02:41 PM Thread Starter
I am about to send out my Victor Jr intake and have a few question..
#1)The flange where the carb bolts to appears to be inclined toward the front of the car is this normal..
#2)On my Torker manifold Now I Have the manifold drilled for manifold vacuum to my Vacuum advance...Ther is no such output on my Victor Jr...Would I loose any Vacuum pressure if I were to T off the line that goes to my TH400...Or should I drill and tap the Victor Jr for manifold Vacuum??
#3)Anyone know how many Manifold Vacuum ports are on a Edelbrock
#4)And last anyone ever had one of these Victor Jr Jet coated...Seems like it would be dificult for them to polish all the crevices..
Thank You Again
Restored 68 Camaro R/S 327 4 speed
Restored 55 chevy Belair
Blown, Fuel Injected
http://community.webshots.com/user/badcaiman
Badcaiman is offline
post #2 of 3 (permalink) Old Jun 5th, 02, 05:05 PM
Jody
camcojb's Avatar
1. I thought mine was pretty level but having it slant to the front is pretty common and no problem since it counter-acts the engine slanting towards the rear in most vehicles.
2. I drilled and tapped my own fitting but I don't see a problem teeing it to that either.
3. Four I believe; one front/rear for pcv or power brakes (large nipple). One small for ported vacuum and one small for manifold vacuum.
4. I had mine polished first, then powder-coated and it looked very good. If you don't have it polished first, it will look rough due to the bumps on the casting.
Jody
camcojb is offline
post #3 of 3 (permalink) Old Jun 5th, 02, 05:20 PM
The carb flange tilt is normal on a Victor Jr., a lot of race manifolds have that to keep the carb level during launch. On my Vic Jr. I pull vacuum from the carb itself- the vacuum advance from the ported vacuum on the side of the carb and the trans vacuum from the carb base at the rear. This is on a Holley 650.
Any good polishing shop should be able to do a Victor, I've seen plenty of them polished. Just remember you have to keep that sucker clean once you polish it!
68 Camaro 355", TH-400, 3.73 10 bolt, Rally rims.
69 Nova 355" TH-350, 4.88 12 bolt, 150 shot...click here to see it.
And a garage full of vintage bmx bikes.
pete b is offline
