fan shrough install - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 8 (permalink) Old Jun 10th, 02, 12:26 PM Thread Starter
Send a message via AIM to tl757
Sorry spelt Shroud wrong
Okay, just a simple one. Put the radiator on and then moved on to the shroud. Is it only held in place by the top bolt that has a metal piece from it to the support. Are there any other place to secure it or just on the top?
Tim
[This message has been edited by tl757 (edited 06-10-2002).]
tl757 is offline
post #2 of 8 (permalink) Old Jun 10th, 02, 01:14 PM
Vintage 68's Avatar
The bottom is secured by two small "S" clips that fit on both sides at bottom and attach to the radiator.
The clips are available from most of the repop houses including the site sponsor at bottom of page.
Vintage 68 is offline
post #3 of 8 (permalink) Old Jun 11th, 02, 04:01 AM
i'd also like to add that the shroud needs to be coaxed to get it into the lower clips - the plastic should flex enough to get the shroud onto them.
Tybor Cook
68 convertible
70 cutlass supreme conv.
lola68rag is offline
post #4 of 8 (permalink) Old Jun 11th, 02, 04:26 AM
Ken
Would you suggest attaching the shroud to the radiator before putting them into the car or is that even possible?
Winch is offline
post #5 of 8 (permalink) Old Jun 11th, 02, 05:56 AM
One could install the shroud onto the radiator, then install the assembly, only if fan blades are removed.
Shroud on first, over the water pump, then slide in the radiator, then, mount shroud onto radiator. S-clips can be gotten from dealer, $1.83 each. The top of the shroud is held in place by one bolt in the bracket bolted to the radiator support.
post #6 of 8 (permalink) Old Jun 11th, 02, 05:56 AM
I've found it easier to place the shroud over the fan, install the radiator, then connect the shroud to the radiator.
Rons68 is offline
post #7 of 8 (permalink) Old Jun 11th, 02, 06:03 AM
Ken
How about the bracket that goes on the radiator support. Do you put it on before either radiator or shroud or does it get in the way like the huge one for the 6 cyl?
Winch is offline
post #8 of 8 (permalink) Old Jun 11th, 02, 06:06 AM
Regarding the top bracket, I don't think that it will matter when you put it on.
Rons68 is offline
