VACUUM LINE HOOK UP - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 9 (permalink) Old Jun 11th, 02, 02:09 PM Thread Starter
Hello,
I am nearing the end of my engine swap and have a question on the vacuum lines. What should be connected and where. I have power brakes, and A th-350 transmission with an electrical detent switch. I noticed another vacuum hose that runs to the transmission as well, is this suppose to be hooked up. I have a 650 holley carb, I know the vaccuum advance from the distributer should run to the carb. I guess the question I have is I want to make sure I hook up the right lines, to the right places. I know an EGR? fitting to the valve cover was there on the old engine, do I need to hook another one up or just use breathers. I have two holes on one valve cover and one on the other. Sorry for all the questions, but want to get it right, before firing it up. It is a vortec 383 chevy. Thanks in advance.
mark67ss is offline
post #2 of 9 (permalink) Old Jun 11th, 02, 02:13 PM
you should probably hook your transmission's vacuum line, and your power brake booster line to a vacuum fitting on the intake manifold. Yes, distributer goes to carb.
boodlefoof is offline
post #3 of 9 (permalink) Old Jun 11th, 02, 03:23 PM
TH350's don't have electrical detent switches..Are you sure it's not a TH400? TH350 has a cable detent and a modulator line
1967 Panther is offline
post #4 of 9 (permalink) Old Jun 12th, 02, 12:11 AM Thread Starter
Yes your right it is a cable detent switch.It definately is the Th-350 What is a modulator line? Does it need to be connected to a vaccuum source? Also, what about the valve that connects to the valve cover EGR? Do I need to connect that or can I use a breather. I have three holes in the valve covers, two on one side and 1 on the other. thanks in advance
mark67ss is offline
post #5 of 9 (permalink) Old Jun 12th, 02, 06:25 AM
Gene
You will need to get the proper fitting for the intake manifold. The tranny vacuum line and the power brake booster will both connect to it.
Your car doesn't have an EGR valve, do you mean PCV valve? If so, there should be a large vacuum port somewhere on the baseplate of the carb. That is for the PCV valve. Run that line from the port to the PCV valve, which will fit on one of the holes in the valvecover.
On the opposite valve cover, you can install either a push in breather, or run a line to the bottom of the air clearner houseing. The latter is how GM did it. All of the parts are available from Camaro suppliers.
The third hole should be the oil fill hole.
There are differning opinions on where to hook up the vacuum advance line. There are two possible vacuum ports on the carb. One is a ported vacuum source and the other is an unported vacuum source. Try both and use the one that makes the car run the best.
Pearl blue & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my website updated 6/10/02 at:
www.geocities.com/gheatly
gheatly is offline
post #6 of 9 (permalink) Old Jun 12th, 02, 11:25 AM
gheatly
I just sent out my Victor jr intake to be coated..It does not have any manifold vacuum port...I was going to run my vacuum advance and my tranny from the manifold port on my edelbrock carb using a T fitting..Do you see a problem with this??? Or should I tap my manifold when I get it back??? really don't want to unless you see a problem..
Restored 68 Camaro R/S 327 4 speed
Restored 55 chevy Belair
Blown, Fuel Injected
http://community.webshots.com/user/badcaiman
Badcaiman is offline
post #7 of 9 (permalink) Old Jun 12th, 02, 11:59 AM
Gene
When you say manifold port on the back of the carb, do you mean the large vacuum port for the PCV valve? I think so, and what you are proposing should be fine.
gheatly is offline
post #8 of 9 (permalink) Old Jun 12th, 02, 12:07 PM
gheatly
On my edelbrock I was planning on using the small manifold port in the front(I have 3 ports in the front a big one for the pcv valve, a small ported vacuum and another small vacuum port which is unported) I am planning on t'ing off the small unported vacuum port..Would that be OK??
Thanks again
post #9 of 9 (permalink) Old Jun 13th, 02, 05:05 AM
Gene
Badcaimen, Here is an old thread with a very good discussion of using a ported vs unported vacuum source for distributor advance. I would read it and see what fits your engine. Bottom line, try both and see which one works best with your combo.
https://www.camaros.net/forum/Forum4/HTML/001671.html
That would be ok for the tranny, as it needs an unported/manifold vacuum source.
[This message has been edited by gheatly (edited 06-13-2002).]
gheatly is offline
