Arp Bolt Washers... - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 5 (permalink) Old Jun 23rd, 02, 05:41 AM Thread Starter
As some of you have been following along..I just completed a head change and am now second guessing my self about certain things...Here is another thing that is driving me crazy..The ARP head bolt washers are concave on one side and now read they should be placed the round side up(ARP never mentions this..Read it at felpros site)...Now I am not sure if I put them all in with the round side up..Anyone know if this is going to make a difference..Thanks
Restored 68 Camaro R/S 327 4 speed
Restored 55 chevy Belair
Blown, Fuel Injected
http://community.webshots.com/user/badcaiman
Badcaiman is offline
post #2 of 5 (permalink) Old Jun 23rd, 02, 08:47 AM
Tony
Yes it will make a difference. The concave side of the washer fits against the radius of the bolt head where it meets the bolt shank (for stregth). If the square inside diameter is against the bolt head it can bind and stress the bolt into early failure. This is a proven method with the aviation industry as all stressed bolts are made this way. That is why the washer's are called AN Washers (just like braided line fittings).
Sometimes you can tell if the washers are installed incorrectly by looking for a gap between the bolt head and the washer. But this is not a fool proof method. There is only one way to be 100% positive about the correct installation if there has been doubt. Take them out and check.
TONY
67 CAMARO R/S CLONE, 355/turbo 350, 200hp NOS,12 bolt,etc...
idoxlr8 is offline
post #3 of 5 (permalink) Old Jun 23rd, 02, 08:14 PM
SY1
Tony is right. They can only be installed with the chamfered side of washer towards the radius of the bolt where the shank meets the bolt head. Goodyear Braking Systems makes washers with both sides of the inner diameter chamfered for aviation applications to prevent improper installation, it's too bad ARP didn't do this as well.
You'll have to take them out and make sure they are installed correctly. You will want to inspect the radius area of each bolt as well to make sure you haven't scored it. If you have replace the bolts as well.
SY1 is offline
post #4 of 5 (permalink) Old Jun 24th, 02, 04:05 PM Thread Starter
Thanks for the info guys..Took the bolts out one at a time and retorqued..They were all correct..Go figure...Thanks
post #5 of 5 (permalink) Old Jun 24th, 02, 04:37 PM
joe
I had another problem with ARP head bolts. The washer and bolt head stuck up so high they hit my header flange. (on the lower head bolts) The interference was just enough so you could not get the header bolts in. I didn't like the small head of the ARP bolts anyway so I changed them for a set of original style bolts with correct markings.
JOE58 is offline
