Bent header collector flange??? - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 13 (permalink) Old Jul 3rd, 02, 02:56 PM Thread Starter
I bent the collector flange on my exhaust system..I have tried 2 dead soft aluminum gaskets and I stll get a leak at the collector..(The flange that tightens it to the header is bent..Over tightened)
I remember seeing something that actualy replaces the collector flange made out of thick aluminum..It actually comes in 2 pieces you cut off the old one and slide this on and bolt it to your header giving you a solid seal to the header..
Anyone familiar with this..I need a name for it and a place to purchase it...
Thanks in advance
Restored 68 Camaro R/S 327 4 speed
Restored 55 chevy Belair
Blown, Fuel Injected
http://community.webshots.com/user/badcaiman
76 Limited edition T/A # matching
26 Ford Roadster..Pro street
79 Corvette..Frame off restoration..
Badcaiman is offline
post #2 of 13 (permalink) Old Jul 4th, 02, 01:55 AM
frank
Why not try straightning it? Heres an idea that may work. Take a couple pieces of keystock (1/2x1/2) should do it and using clamps, clamp the ends to the collector. Now use some more clamps in the middle, and it should pull the whole thing out straight.
frankk is online now
post #3 of 13 (permalink) Old Jul 4th, 02, 04:27 PM
Jc whitney sells the repair collector that your talking about.
ochrisl is offline
post #4 of 13 (permalink) Old Jul 4th, 02, 05:15 PM
why not just do what i did- cut off the 3 bolt collector, and use stainless steel band clamps on it. get them tight, and they don't leak. and they will not get caught on anything and bend a header like happened to me. the bands are about $10 a piece and can be purchased at any good parts store or diesel mechanic shop. might seem kinda spendy, but you'll never have to look at them again if you don't want to.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #5 of 13 (permalink) Old Jul 5th, 02, 12:33 AM Thread Starter
OCHRIS..I have looked all over the JC Whitney book and web site..and have found ZIP.Do you have a part #
NOVADERRICK..I don't quite get what you are describing with the bands...But I would rather not cut off the collector..
Someone here has to know what I am talking about..The summit tech new..could describe it to me in detail..just couldn't tell me where to get it or the correct name..He called collector repair flange(Sounds Good but I don't think it is correct)...
Thanks again I appreciate all the response
79 Corvette..Frame off restoration..(Don't ask WHY )
post #6 of 13 (permalink) Old Jul 5th, 02, 06:38 AM
I've always pinned the collectors together with loose bolts and using 2 hammers (one on each side) and have brought them together... for a while...
I like the stainless clamp idea, i use them on my diesel truck with great success
68ragtop is offline
post #7 of 13 (permalink) Old Jul 5th, 02, 10:30 AM
Bill
Bad,
What most people do not realize, is that the flange itself is not what the gasket seals on. It can be bent a fair amount nd still work. If you look at the front end of your actual exhaust pipe, you will notice that it has a slight lip on it. This is what the gasket actually seals on. If the lip is bent up, or badly corroded, it does not matter how good the flange is, it still will not seal. Take a very carefull look and you will see what I am talking about. Make sure everything is straight and it should seal up, even with the bent flange.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1973 Z-28 ..one family car...Brother bought it new in 73
BillK is offline
post #8 of 13 (permalink) Old Jul 5th, 02, 11:33 AM
I didnt see it in the catalog either.I bought it about two years ago.I still have one if you still need it.Let me know.
ochrisl is offline
post #9 of 13 (permalink) Old Jul 5th, 02, 01:07 PM
here is what i am talking about
http://www.jegs.com/cgi-bin/ncommerc...80&prmenbr=361
it just wraps around the pipe and clamps evenly all around. after using these, i don't think i can ever go back to regular header flanges or exhaust clamps.
[This message has been edited by novaderrik (edited 07-05-2002).]
post #10 of 13 (permalink) Old Jul 5th, 02, 05:10 PM Thread Starter
68RAGTOP..I have thought of your hammer idea..But don't have the room..The entire exhaust system is welded..
BILLK..I know the lip you are referring to..and it appears in good shape..no rust..The however the collectors flange does have a good blend(always seem to overtighten things )..I have even tried double dead soft aluminum gaskets..Still leaks
OCHRIS..Is ther a chance you have a pic..just to make sure it is what I am talking about..
NOVADERRIK..I see now what you mean..But still would rather not cut the header..But won't dismiss the idea either..
Thanks guys I really appreciate all the help
post #11 of 13 (permalink) Old Jul 7th, 17, 06:58 PM
Probationer
Anthony
Billk raised a important point about the flair part of a separated or 2 part flange pipe. Another consideration that should b mentioned is the result of heat and vibration in the connecting flanges. I had continuing failures at the flanges. Flattening and replacing the gasket was not enough. Vehicle inspections due to leaks at the flanges resulted in rejection stickers. I found something that worked.
C Flange Bracket
https://youtu.be/zBdFKlVRh48
JoePublicVA is offline
post #12 of 13 (permalink) Old Jul 7th, 17, 07:01 PM
Probationer
Anthony
C Flange Bracket info
Name:	What is a C Flange Bracket ver 20170301 pg1_1499479180074.jpg
ID:	187154   Click image for larger version
Name:	What is a C Flange Bracket ver 20170301 pg2_1499479248879.jpg
post #13 of 13 (permalink) Old Jul 8th, 17, 04:47 AM
mike
Re: Bent header collector flange???
I also cut the flanges off and used slip on collectors and have more ground clearance and have never had to touch them again.
bigblockragtop is offline
