Need recommendations on torque converter.. - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 5 (permalink) Old Jul 7th, 02, 03:00 PM Thread Starter
OK..Guys am ready to order new torque converter..Here is my setup..
355 SBC 10-8-1
23 trick flow heads
Victor Jr intake
lunati Cam [email protected] 515 Lift 108 LSA
Edelbrock 750 Mech
Headers
HEI
TH400
9" rear with 370
The car is NOT a daily driver..Car shows, track time and some weekend highway/around town cruising.......
Car weighs in at 2350lbs with driver..
Would like recommended stall speed and the name of some manufactures(Also what makes one converter better than the other)
Thank you
Restored 68 Camaro R/S 327 4 speed
Restored 55 chevy Belair
Blown, Fuel Injected
http://community.webshots.com/user/badcaiman
76 Limited edition T/A # matching
26 Ford Roadster..Pro street
79 Corvette..Frame off restoration..(Don't ask WHY )
Badcaiman is offline
post #2 of 5 (permalink) Old Jul 7th, 02, 04:54 PM
With 3:70 gears you will be turning from 2800 to 3000 at cruse speed depending on tire size. Stay below that on the stall and when you do cruse some it will be above stall speed plus this should get you off the line good.
Larry www.lnjstreetrods.com
[This message has been edited by lnjstreetrods (edited 07-07-2002).]
lnjstreetrods is offline
post #3 of 5 (permalink) Old Jul 7th, 02, 05:33 PM
Send a message via AIM to CamaroNOTcamero
ATI is one of the best www.atiperformanceproducts.com
What makes one better then another is more torque multiplication, less low end slippage (if you want a streetable one) while retaining a high Flash Speed.
CamaroNOTcamero is offline
post #4 of 5 (permalink) Old Jul 8th, 02, 12:51 AM
CNC said it best, no one knows better than the t/c manufacturer.
Give your choice a call and they will help you in selecting the correct convertor.
I would shy away from GER, good prices for the budget minded, but, quality is alittle defunct. ATI is a good company, so is B&M. Might try Georgia Convertor.
post #5 of 5 (permalink) Old Jul 8th, 02, 01:26 PM
scott
Another vote for ATI. Call them, answer all the questions they ask and your done. Great convertors also.
SCOTT
69 RS-SS 396 4-SPEED
scottcleaver is offline
