Tips on plugging end of Muncie for removal - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 11 (permalink) Old Jul 8th, 02, 04:48 AM Thread Starter
Ken
I don't have a spare drive shaft yoke so I'm looking for suggestions on how to plug the tailshaft end of a Muncie to keep fluid from running out when I remove it. I saw a tailshaft plug at Summit but there's no description. Not sure what if it will fit. Any other ideas?
Winch is offline
post #2 of 11 (permalink) Old Jul 8th, 02, 05:33 AM
Bruno
Drai it, it's a good chance to do an oil change anyway. Leave it overnight and tie a rag over the end when removing it.
ORENCH is offline
post #3 of 11 (permalink) Old Jul 8th, 02, 05:46 AM Thread Starter
Ken
But I just installed it and filled it. I've heard about tying a sandwich bag around it and I was thinking about something like an empty plastic caulk tube end if it would happen to be the right diameter. I thought somebody might have done something similar.
Winch is offline
post #4 of 11 (permalink) Old Jul 8th, 02, 06:01 AM
Leave the driveshaft in it until you get it on the floor. This works great if you don't have the car on a lift. If you're on a lift have someone hold the shaft in.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #5 of 11 (permalink) Old Jul 8th, 02, 06:32 AM
I have seen plastic 'dummy' yokes for just this reason.I forget where,Jegs maybe?
ochrisl is offline
post #6 of 11 (permalink) Old Jul 8th, 02, 06:42 AM
Gene
Use Saran Wrap. If the rear flange is clean and oil free, the Saran Wrap will stick to the tranny.
gheatly is offline
post #7 of 11 (permalink) Old Jul 8th, 02, 06:47 AM Thread Starter
Ken
I just pulled it the other day to try a different clutch fork and I did leave the drive shaft in it and then I set it on a milk crate but in the process I have stripped the threads on one of the motor mounts so it's helicoil time I guess (never done that, it will be a new experience). The problem with just leaving the drive shaft in to pull it all the way out is the emergency brake cable under it. I'd rather not unhook that.
I too have seen some add for a plug. I remember it saying no messy sandwich bags which is where I got that idea. But I can't find that now for anything. I guess I'll call Summit if no one has a clever work around.
Winch is offline
post #8 of 11 (permalink) Old Jul 8th, 02, 07:18 AM
head to the boneyard and splugre for a spare yoke- might cost $5, if they even charge you.
also, they sell the plastic plugs at most GOOD auto parts stores.
the plastic bag trick has never worked for me- i always end up with a mess. have left the driveshaft installed before, but only on cars that don't have the e-brake cable under the driveshaft.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #9 of 11 (permalink) Old Jul 8th, 02, 07:47 AM
Bruno
Try this, http://www.ontool.com/store/product/2341
Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench
ORENCH is offline
post #10 of 11 (permalink) Old Jul 8th, 02, 08:42 AM Thread Starter
Ken
That looks like a winner. Thanks
Winch is offline
post #11 of 11 (permalink) Old Jul 8th, 02, 01:40 PM
Winch,
Try hitting up some of the local tranny shops...! They usually have some extras lying around and can sometimes had cheep
Just my .02 worth
Good luck
67 Prostreet is offline
