Used stall converter... - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 3 (permalink) Old Jul 13th, 02, 05:52 PM
xodus921
Guest
Posts: n/a
Good idea or bad Idea? I can get it used for $65 or buy a new one for $150...The used one was used for a year and a half...its a 2400 stall...
The reason I'm considering a used one is because I talked to the guy at TCI and he said My engine and cam want a 3000 stall and my rear wants a 2600 stall and said to go with the 2600. I'm running 3.42's right now. I plan on switching up to 3.73's at least, in a few months and I'll have to get a bigger one later anyway...I dont' have the extra cash at the moment to do everything or I would...
Tony
<UL TYPE=SQUARE>
<LI>1979 Z-28, 350, Th350- Edelbrock Performer RPM cam and intake, Holley 650, Trick flow twisted wedge heads, dynomax headers,flowmaster american thunder exhuast[/list]http://hobbystage.net/camaro/xodus921/
post #2 of 3 (permalink) Old Jul 13th, 02, 06:06 PM
I would want some sort of guarantee, chances are it's fine if it doesn't have a lot of miles on it and hasn't been abused. In any event, I would make sure it has been or gets flushed. Usually this requires drilling a hole (or draining from a plug if you're lucky) to drain the fluid. Then the converter is placed in a flusher that slowly rotates it while pumping filtered solvent through it.
-dnult
[This message has been edited by dnult (edited 07-13-2002).]
dnult is offline
post #3 of 3 (permalink) Old Jul 13th, 02, 06:07 PM
Why can't we delete our own messages...sheez
dnult is offline
