gvw 68 - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 7 (permalink) Old Jul 14th, 02, 05:56 PM Thread Starter
SS
Car is a small block 4-speed car with multileafs and 12bolt added weight is 4-point rollbar and steel scatersheild with motor plate, how much does it weigh.
railing68 is offline
post #2 of 7 (permalink) Old Jul 15th, 02, 12:51 AM
Two things you can do to determine the weight,
1. Look at registration, it might have shipping weight of car, then add shipping weight of roll bar, scattershield, and motor plate. This will be an estimate.
2. Fill all fliuds and weight it at a moving company scales or your local grain elevator scales, cost maybe $5.
I would guess 3450-3600 Lbs. if full interior.
post #3 of 7 (permalink) Old Jul 15th, 02, 09:28 AM
also a local stone yard or asphalt plant will have scales,just ask before you pull on
and if they don't have print a ticket they might not charge.....I never do.
any way my 67 s/b 4 speed 10 bolt,no cage wieghted 3320 lbs.
good luck!
Oncea3Fan is offline
post #4 of 7 (permalink) Old Jul 15th, 02, 05:36 PM
the local land fill/recycling center around here has a scale and they don't charge. I'm going there after I finish my summer work and see how much weight I dropped.
www.geocities.com/boodlefoof
boodlefoof is offline
post #5 of 7 (permalink) Old Jul 16th, 02, 03:41 PM
Sean
another good place is a state weigh station. i've got one close to my house, and my buddies and i have used it many times. if you go there when they aren't open (obviously) you can just pull on the scales, and you can see the reading through the window. they even pont them out the window sometimes, i think so truckers can check themselves.
68rs406 is offline
post #6 of 7 (permalink) Old Jul 17th, 02, 04:25 AM
Ken
I used a state highway weigh station once for my 67 Vette coupe 327 with me in it and it weighed 2750. I've always wondered how acurate those scales are for a vehicle much smaller than they are used to weighing. Anybody know if 2750 sounds right for that car? Seems light to me.
Winch is offline
post #7 of 7 (permalink) Old Jul 19th, 02, 09:30 AM
JohnZ's Avatar
SB 327 '67 Corvette coupe with no options weighs 3185# empty.
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
