Hood won't shut! - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 5 (permalink) Old Jul 17th, 02, 05:31 PM Thread Starter
I just changed out my cast iron intake and Quadrajet for a Weiand Hi-rise aluminum intake and 750 Holley carb on my 67 small block.
Now my hood wont close!I went out and bought a triangle shaped open element,that wont work.The only thing I can get to fit is a little 6 inch breather,which is choking my motor.
Has anyone else ran into this?And if so did you have to cut the hood frame.Oh and yes I have also tried a dropped breather.
Thanks for any advice.
Camn67 is offline
post #2 of 5 (permalink) Old Jul 17th, 02, 05:53 PM
I would guess you bought the x-celerator or team g manifold. You should have gone with the stealth. The only advice I can give you're not going to like. Either get a different intake or buy a cowl hood.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #3 of 5 (permalink) Old Jul 18th, 02, 02:01 AM
Send a message via AIM to Spames
Do you have a drop base air cleaner?
I run an Edelbrock Torker, and I can get a 2" air cleaner under my hood.
68 Coupe, 350 4-speed
Jim's Camaro Corner
Spames is offline
post #4 of 5 (permalink) Old Jul 18th, 02, 03:14 AM
I have an x-celerator and Holley 750 on my 350 in the 69. I already had an original cowl hood. That combo fits under the hood nicely with the Weiand air cleaner. The x-celerator is too tall for the flat hood.
69 SS, 350, 4 Speed
75 400, 4 Speed
93 Z28, 6 Speed
69X11SS is offline
post #5 of 5 (permalink) Old Jul 18th, 02, 10:06 AM
Gene
You should be ok with a Moroso drop base air filter housing. I had an Edelbrock Torker II (new style) on my car with a flat hood, the Moroso air filter housing and a 3 inch K&N filter. The Torker II is only a few thousanths of an inch shorter than the Weiand Team G.
gheatly is offline
