Car Lift - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 14 (permalink) Old Aug 7th, 02, 01:46 PM Thread Starter
I am looking for good and bad feedback on any car lifts. Not something too radical, just enough to lift my el camino and change some parts when I need it. I won't use it for storage of another car on top, scares me too much with my 6 year old. thanks Dino
Dino is offline
post #2 of 14 (permalink) Old Aug 7th, 02, 06:46 PM
Charley
clill's Avatar
I have a Backyard Buddy and it works fine.
clill is offline
post #3 of 14 (permalink) Old Aug 7th, 02, 06:49 PM
Jeff
Jeff 67/68 & 69 RS's
65 442 http://hobbystage.net/camaro/hawaiiancamaro/index.html http://www.hawaiianislandcamaros.org
[This message has been edited by HawaiianCamaro (edited 08-08-2002).]
HawaiianCamaro is offline
post #4 of 14 (permalink) Old Aug 8th, 02, 02:25 AM
Send a message via AIM to Spames
WHEW! I thought you were looking for a lift kit for your car.
68 Coupe, 350 4-speed
Jim's Camaro Corner
Spames is offline
post #5 of 14 (permalink) Old Aug 8th, 02, 05:35 AM
Jody
camcojb's Avatar
I have one from Eagle Equipment. I really like it. However, if I had it to do again, I think the Backyard Buddy that Clill has is a little nicer. It goes up faster (which is probably due to his being 220V and mine is 120V), but the jack trays are also nicer.
Jody
http://www.camcojb.com/
camcojb is offline
post #6 of 14 (permalink) Old Aug 8th, 02, 09:01 AM
My brother has one of the Gemini lifts. He had it modified so it's down in the ground under the garage floor. He can park a car on it and lower it down. When it's closed it has a steel diamond plate top that becomes the garage floor and he parks his other car on it at ground level. Pretty slick.
'69 400SB, Richmond 5-speed
www.geocities.com/sdenning1
RockyMtnRacer is offline
post #7 of 14 (permalink) Old Aug 8th, 02, 09:37 AM
What about a dual post lift? That gives you the added flexibility of being able to work on axles, brakes, and other jobs that require tire/wheel removal.
Would a dual post lift work with the camaros?
K.A. Young
67 SS 350
PowerGlide AT
AC, Deluxe Interior
Daily Driver
67L48 is offline
post #8 of 14 (permalink) Old Aug 8th, 02, 09:51 AM
Rick
I bought the Perfect Park 7000 after looking at several at Carlisle and am very please with it.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
RickD is offline
post #9 of 14 (permalink) Old Aug 8th, 02, 11:23 AM
Jody
camcojb's Avatar
I looked at the 2-post lifts but it seemed like a hassle to always have to set the thing correctly under the frame areas every time you want to lift your car. If you were doing almost all brake jobs, etc. where the tires had to be removed constantly it might be a better way to go. They have jack trays that allow you to remove the tires and wheels very fast on the 4-post types anyway.
Jody
www.camcojb.com
[This message has been edited by Camcojb (edited 08-08-2002).]
camcojb is offline
post #10 of 14 (permalink) Old Aug 9th, 02, 07:55 AM
Try www.kwiklift.com I have one and I like it.
68 RS, Ash Gold,pwr brakes,pwr windows,Hounds tooth,355/T350,MSD 6AL,3200 stall Dynamic converter,3.31:1 posi,Autometer guage pod
CA420 is offline
post #11 of 14 (permalink) Old Aug 9th, 02, 01:40 PM
I purchased the Perfect Part 7000 and have no problems. 4 post and works with 110v. A couple of us put it together in an afternoon. Hard to unload from the truck it was pretty heavy. Needed a few neighbors, but well worth it.
Jim J is offline
post #12 of 14 (permalink) Old Aug 9th, 02, 05:15 PM
If you're going to spend the money for a lift, get one that will allow you to walk under the car (you're back will rejoice). Even if you have to modify you're garage to do it, it is well worth it. They're not that much more than the brake job type lifts.
Kyvox is offline
post #13 of 14 (permalink) Old Aug 10th, 02, 01:27 AM
I also have the Perfect Park 7000. Nice lift and I was able to assemble it myself, although having another helper would have been nice.
69 BMotion is offline
post #14 of 14 (permalink) Old Aug 11th, 02, 03:27 PM
Rotary 9000 lb. isometric
Branded is offline
