Timing setting - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 2 (permalink) Old Aug 22nd, 02, 07:07 PM Thread Starter
What is a good setting for timing on a sbc 305 engine. I currently am running 16 btdc initial. If I give too much advance will this cause my car to take off slower or faster? I am curious because with more advance it seems to go quicker initially. But maybe it is just me. Thanks
peters76 is offline
post #2 of 2 (permalink) Old Aug 23rd, 02, 12:49 AM
TJ
I believe most folks start with 8 degrees BTDC and then go from there. Too much and you are asking for a piston with a fresh shiney hole in the top, but generally, advancing it bit by bit from the initial wil gain you slightly more torque at low RPM while sacrificing a bit of HP way up in the rips.
BreathWeapon is offline
