3 speed to 4 speed - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 4 (permalink) Old Aug 26th, 02, 12:15 PM Thread Starter
Could anyone let me know if originally a car(69 camaro) had a 3 speed manual and to change over to to a 4speed m22 would the shifter be in the same location of the tunnel or would it be futher back?
mymax is offline
post #2 of 4 (permalink) Old Aug 26th, 02, 03:27 PM
Gene
I had to remove about 2 inches of metal at the rear of the 3 speed hole in order for the Muncie shifter to be centered in the 4-speed shifter boot retaining ring while in neutral. The 3-speed hole is not rectangular like the 4-speed hole, so it won't be a perfect fit.
gheatly is offline
post #3 of 4 (permalink) Old Aug 27th, 02, 04:31 AM
Ken
My 68 swapped with no problems. I used an M20 with Hurst Comp+ that bolted onto the rear housing with a big U bolt. Probably is different than the setup your looking at though.
Winch is offline
post #4 of 4 (permalink) Old Aug 27th, 02, 05:46 AM
Gene
I used a '69 GM Hurst shifter. It may fit differently than the Hurst aftermarket version. It did not use the u-bolt.
gheatly is offline
