On Board computer - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 4 (permalink) Old Aug 31st, 02, 07:32 PM Thread Starter
can someone tell me what year they started using computers in the camaros? i have an 84 camaro and was wonderngit it has a computer
Bantam is offline
post #2 of 4 (permalink) Old Aug 31st, 02, 09:48 PM
As far as I know 1981 was the first year for the ECM on Camaros. Your '84 definetly has one, unless someone took it out.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #3 of 4 (permalink) Old Sep 1st, 02, 01:05 PM Thread Starter
ok thaks, i found the computer on the passenger side under the dash, now is there a way to check for error codes? i know in chryslers you turn the ignition on and off 5 times and count the flashing light to determine the error codes. does the camaro have a similiar feature?
Bantam is offline
post #4 of 4 (permalink) Old Sep 1st, 02, 07:52 PM
There's a diagnostic plug under the dash usually on the driver's side. Find the ground wire (black with white stripe) and put a jumper between it and the wire next to it. Turn the key to the on position and count the check engine flashes. It will flash the first digit short pause and then the second digit. Flash, pause, flash flash = code 12. It does each code three times I think followed by a long pause and then the next code. It will always flash a code 12 which is no distributor signal because the engine's not running.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
