'69 shifter in a '68 - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 4 (permalink) Old Sep 30th, 02, 04:29 PM Thread Starter
Will a factory Hurst shifter from a '69 Camaro fit and work well in my '68 with console?
shayne99 is offline
post #2 of 4 (permalink) Old Oct 1st, 02, 03:06 AM
Should work, Make sure you get all of the donor parts, like the mounting plate, and shifter arms,
Other way is buy the coplete install kit from Hurst Shifters,
Good luck,
Rob.Canada is offline
post #3 of 4 (permalink) Old Oct 1st, 02, 08:16 AM
The problem comes from the tranny. The 68 and 69 tranny hookups are different. If you have a 69 tranny, go for it. If you have a 68 tranny, you need a 68 shifter setup. You will not be able to just bolt it on and go.
-Mark.
stingr69 is offline
post #4 of 4 (permalink) Old Oct 1st, 02, 11:02 AM
Sixty-eight and older had 5/16-18 studs on the shift fork exposed from the trans side plate.
Sixty-nine and newer are 3/8-16 threaded holes in the same place making the item a larger overall diameter, hence, a bigger slot in the shifter's shift arm to fit.
Everett "OBJECTS IN THE MIRROR DISAPPEAR UPON RAPID ACCELLERATION"
Everett#2390 is online now
