Alternator Bracket - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 2 (permalink) Old Oct 16th, 02, 09:04 AM Thread Starter
I own a 67 Camaro RS. Does anybody have a good method of mounting the lower alternator bracket to the headers. I have the correct bracket for the application. My problem is, it is always comming loose. Like the bolts aren't getting a good enough bite. Kind of makes you a little nervous about driving it out of town.
62bakes is offline
post #2 of 2 (permalink) Old Oct 17th, 02, 09:01 AM
have you tried longer header bolts?
or, if the head has accessory holes tapped into the end, go get an alternator bracket off a late 60's/ early 70's (up to 72) truck with a 350 in it. they had the short waterpump, and mounted the alternator bracket right on the end of the head. pretty slick.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
