1969 Heater Control Unit - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 7 (permalink) Old Oct 21st, 02, 10:09 PM Thread Starter
I have a unit that is missing a knob to move one of the the levers. Lever is there and works if I use a screw driver to move it back and forth. Is this something that can be repaired and if yes any suggestions as to where I can send it?
Ken
Ken Miele is offline
post #2 of 7 (permalink) Old Oct 22nd, 02, 02:06 AM
It doesn't sound like there is any repair work to be done. You just need a replacement heater control knob. These are available from most of the first gen supply houses. They just push on.
kurt6325 is offline
post #3 of 7 (permalink) Old Oct 22nd, 02, 03:02 AM
I broke a lever on mine while trying to pull off one of the knobs. The lever (slide) broke even with the face of the unit not allowing a new knob to go back on. I tried many different ways to glue it back on to no avail.
I ended up buying another unit (used) that wasn't broken.
I believe the parts houses (Rick's, Ground Up, etc.) sell them used (when available) and there may be a repro item now.
'69 Z11 Pace Car, 350/4 speed, manual top, console w/gauges, tilt rosewood wheel, AM radio
drdave69 is offline
post #4 of 7 (permalink) Old Oct 22nd, 02, 04:08 PM
To get the knobs off you need to use pliers and a protectant rag and work the knob up and down while pulling. It's very difficult to remove the knobs just by pulling them straight out.
kurt6325 is offline
post #5 of 7 (permalink) Old Oct 23rd, 02, 05:55 PM
Gary
I bought a heater control off E Bay for $40. I have seen these in quantity for sale at Carlsile!
Gary Dorion is offline
post #6 of 7 (permalink) Old Oct 24th, 02, 12:38 AM
JWA
Jeff
JWA's Avatar
Classic industries lists a complete heater control unit for $140 if you have to have new. try matts classic bowties in the bbay area. They usually have the CI stuff cheaper than CI.
Jeff
69 SSRS 396(roller 427 )
My Chevs
JWA is offline
post #7 of 7 (permalink) Old Oct 24th, 02, 10:24 AM
the early 70s Novas used the same unit. Usually a lot cheaper through ebay
69 convertible
LT1 4L60E
red69camaro is offline
