need id help on 69 l78 camaro - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 2 (permalink) Old Nov 25th, 02, 05:00 PM Thread Starter
I'm in process of buying a 69 camaro L78 and need help on Id ing it the last letters on block are jh which seems correct, but tranny is a m21 and I thought you could only get a m22 in L78 what else should I look at to verify?
idareya is offline
post #2 of 2 (permalink) Old Nov 25th, 02, 05:35 PM
Gary
M22 was an option, not standard on L78.
JH is correct for L78 w/standard shift. Check the VIN on the engine. It will be either on the engine pad, by the JH code, or down on a flat by the oil filter.
Other clues to original L78 would be single fuel line (and no evidence of it ever being dual line, like fuel line clips, sending unit). 6000 redline, 7000max factory tach.
Evidence of ordinary b/b has been well documented on this forum. do a search
Hope it's a real one!
Unreal is offline
