69 Chevelle tilt steering column, need pics/diagrams - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 7 (permalink) Old Dec 2nd, 02, 12:44 PM Thread Starter
Hi, I just got a 69 Chevelle tilt column, and am looking to install it in a 68 Camaro, the two are a little different, but I'm sure I can modify it and make it fit/work... I'm trying to find pics and diagrams of the 69 Chevelle column, anyone know where I could find them?? Thanks
TEAM CANADA is offline
post #2 of 7 (permalink) Old Dec 2nd, 02, 12:53 PM
DjD
DjD's Avatar
Try our sister site www.chevelles.com
...Dennis
"The '69, the '96 our local club"
and the "daily driver"
DjD is offline
post #3 of 7 (permalink) Old Dec 2nd, 02, 06:09 PM
The 69 has the key cyl and switch in the column.This could be a problem,unless you were planning on doing away with the switch in the dash.
69 Camaro SS 350 4 speed
71 Nova
gene stills is offline
post #4 of 7 (permalink) Old Dec 2nd, 02, 06:16 PM Thread Starter
Ya, I took the cylinder out, dont want it, I want it to look stock, just need some diagrams, to see how similar the two are, they seem to be the same length
post #5 of 7 (permalink) Old Dec 4th, 02, 06:22 PM Thread Starter
okay for anyone who cares, heres the diagrams:
http://chevelles.com/showroom/Bow_Ti...t_69column.jpg
http://www.team67.com/groups/group.0...olumn_tilt.htm
does anyone know what the purpose of "reverse lockout" is, my cars a 4speed, and originally the camaro didnt have it... the chevelle column had it..
post #6 of 7 (permalink) Old Dec 5th, 02, 04:35 AM
the reverse lockout was to lock the steering column from turning. There was linkage called "backdrive linkage" from the trans to that lever on the bottm of the column, and what it did was rotate the column collar to the lock position when the car was put in reverse. This also allowed the ignition key to be turned all the way off and removed. If the car wasnt put in reverse you couldnt turn the key all the way back to remove it.
Since you wont be using the ignition key it wont be needed for you.
66/70 chevelle ss396's
72 chevelle
69/71 camaros
55 chevy prostreet
61 impala bubbletop
drptop70ss is offline
post #7 of 7 (permalink) Old Dec 6th, 02, 04:44 PM Thread Starter
thanks droptop, I guess I'll cut it off, get rid of it, cheers
