Rochester Carburetor - Team Camaro Tech
Replies ONLY, no new topics.
post #1 of 5 (permalink) Old Dec 13th, 02, 04:56 AM Thread Starter
In my '69 Camaro I have a Chevy 350cid with a Rochester Quadrajet, stamped:
17083204
2982 FRB
The engine is, I believe, a 1980 truck motor (V0724TDB; C8S219693),I do not know for sure but I assume the carb was for that engine. I've read that most Quadrajets are 750 cfm. Does anyone know where I can get information on the specs for this carb on-line, and what you might suggest for a re-build kit.
I was thinking of picking up "Rochester Carburetors" by Doug Roe or the Mike Stubblefield, John Harold Haynes "Rochester Carburetor Manual".
Any help is appreciated.
hank
Hank Recor
1969 Camaro
"Feel the Burn"
hrecor is offline
post #2 of 5 (permalink) Old Dec 13th, 02, 06:44 AM
Hi Hank
When I get a carb or part number I just plug it into a search engine like www.dogpile.com or www.google.com and usually come up with a link. Here is the first link I came up with and it looks like an 83 Monte Carlo or Caprice carb. http://www.monte-list.nu/parts/carb_numbers.shtml
Actually, the carb rebuild kits that you get from NAPA or Kragen or whereever will have a four page description of float adjustment and other stuff. So, I doubt you even need a book. The rochesters are real easy to rebuild and the rebuild kits have gasket sets for usually four different models of the quadrajet. So, you generally only use about 1/3 of the supplied gaskets in the rebuild kit.
The only things you really need to be careful about is not bending the metering rods when you remove them and not lose the ball bearing/check valve ball.
Take the carb number to your favorite parts store and they will probably have the rebuild kit in stock.
bonecrusher67conv is offline
post #3 of 5 (permalink) Old Dec 13th, 02, 07:06 AM
Here ya go:
Year:1979 Code:TBD CID: 350 STYLE: conv. cab,m/t, EMISSIONS:fed VIN :L LS9 HP:165 BBL: 4 Models: K-10 to 2500
Welcome to the Club!!! Lots of good info AND people.
Everett "OBJECTS IN THE MIRROR APPEAR QUICKLY UPON RAPID DECELERATION"
Everett#2390 is online now
post #4 of 5 (permalink) Old Dec 13th, 02, 08:50 AM Thread Starter
Thanks for the quick reply. I will be carefull when I do the rebuild. It will be my first time.
thanks
hank
hrecor is offline
post #5 of 5 (permalink) Old Dec 13th, 02, 03:59 PM
<BLOCKQUOTE>quote:</font><HR>Originally posted by hrecor:
thanks
hank
<HR></BLOCKQUOTE>
It's fun working on stuff for the first time. Kinda like loosing your virginity all over again.
-dnult
dnult is offline
