ARP bolt problem - Page 3 - Team Camaro Tech
 2Likes
post #31 of 50 (permalink) Old Mar 20th, 19, 01:21 PM
Simon
Re: ARP bolt problem
Opps.... I gave you the bellhousing to back of engine block.
slazisme is offline
post #32 of 50 (permalink) Old Mar 20th, 19, 01:23 PM
bob
Originally Posted by stamatisg1977 View Post
Pretty sure this is the specs on the bellhousing bolts.
https://www.jegs.com/i/Chevrolet-Per...15768/10002/-1
These bolts are higher than grade 8 plus they have the flange under the head.
i figured it out using my thread pitch gauge its 1/2"-13[/QUOTE]
The link you provided shows it being a 10mm bolt diameter....not 1/2"
bob15 is offline
post #33 of 50 (permalink) Old Mar 20th, 19, 01:29 PM
Simon
Uhhh thanks for the update Bob.......see above post #31.
slazisme is offline
post #34 of 50 (permalink) Old Mar 20th, 19, 03:13 PM
kevin
Might just get what i need from bolt depot
While im at it what is the bolt/thread pitch for the transmission to bellhousing?
the bolt size for my Lakewood bell is 1/2-13 I am thinking about 1-3/4"long
not sure
I enjoyed this discussion hope no toes were stepped onmine were not
flat tire is offline
post #35 of 50 (permalink) Old Mar 20th, 19, 04:20 PM Thread Starter
Steven
stamatisg1977's Avatar
Originally Posted by flat tire View Post
the bolt size for my Lakewood bell is 1/2-20. I am thinking about 1-3/4"long
not sure
yes! i learned alot
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is online now
post #36 of 50 (permalink) Old Mar 21st, 19, 01:22 AM
Brett
What good is a rolled thread when the hole it goes in is cut from a tap?
Both the male (External) and female (Internal) threads can be cold formed. We use Roll Taps a lot. But you are correct and I had not thought about that until you mentioned it, haha. Made me wonder about another thing I do not know; Which of the two are stronger - The bolt or the threaded hole?
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #37 of 50 (permalink) Old Mar 21st, 19, 04:18 AM
Rolled thread bolts are stronger than cut threads. Ditto for tapped holes. I gotta say that I hated roll taps though.
3d cad is offline
post #38 of 50 (permalink) Old Mar 21st, 19, 12:42 PM Thread Starter
Steven
Ok new ARP bolts just arrived
Same ****
Going with GM from now on
Tremec TKO 600
post #39 of 50 (permalink) Old Mar 21st, 19, 01:04 PM
Darin
ilikeike's Avatar
Even though youre going with GM bolts, I'd call ARP directly and/or send them a picture.
I would make sure they fix it for the next guy.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is online now
post #40 of 50 (permalink) Old Mar 21st, 19, 02:52 PM Thread Starter
Steven
ARP is sending me out new washers
Tremec TKO 600
post #41 of 50 (permalink) Old Mar 21st, 19, 03:03 PM
Brett
Same ****
Is that package showing the washers on the bolts? I swear I see the washer already on the bolt, but surely not. If you got the washers separate, maybe they are metric and got mixed up.
The Japanese have a good way to insure quality like that; They put the parts together prior to shipping. If you receive the package with the washers on the bolts, you know they fit!
My question was: Which is stronger the male or female, not which are stronger rolled or cut.
Brett.....
post #42 of 50 (permalink) Old Mar 21st, 19, 03:04 PM
kevin
Quality ! made here in the usa.
post #43 of 50 (permalink) Old Mar 21st, 19, 03:27 PM Thread Starter
Steven
Brett.....
no they come seperated the washers are under the bolts
Tremec TKO 600
post #44 of 50 (permalink) Old Mar 21st, 19, 03:35 PM Thread Starter
Steven
They look like they have washers on
Tremec TKO 600
post #45 of 50 (permalink) Old Mar 23rd, 19, 04:10 AM Thread Starter
Steven
With the GM bolts, do i use any lube or are they dry torqued?
Tremec TKO 600
Subframe Body mount bolt just spins Just 1 More Body Shop 12 Mar 11th, 19 04:43 PM
U Bolt size 69 12 bolt ? Craig1969 Transmission & Driveline 2 Mar 11th, 19 12:21 PM
An Evolving Problem CityguyUSA Engine 10 Dec 31st, 18 07:52 AM
Cracked Off Front Fender Bolt - 1968 BronzeDevil Body Shop 25 Oct 17th, 18 07:20 PM
head bolts flat tire Engine 2 Feb 2nd, 18 11:53 AM
