ARP bolt problem - Team Camaro Tech
 2Likes
post #1 of 50 (permalink) Old Mar 19th, 19, 04:17 AM Thread Starter
Steven
stamatisg1977's Avatar
ARP bolt problem
Got the kit 134-2203 pressure plate bolts
Washers are too small and dont fit over the threads
Anyone else ever experience this and what did ARP do to correct?
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 50 (permalink) Old Mar 19th, 19, 04:22 AM
kevin
Re: ARP bolt problem
I have just used grade 8 bolts and washers for the pressure plate.
I would just head to the hardware store and get the proper washers
it would be quicker in the long run
I would still contact them about the wrong size washers
flat tire is offline
post #3 of 50 (permalink) Old Mar 19th, 19, 05:07 AM Thread Starter
Steven
Might just get what i need from bolt depot
While im at it what is the bolt/thread pitch for the transmission to bellhousing?
Tremec TKO 600
post #4 of 50 (permalink) Old Mar 19th, 19, 08:35 AM Thread Starter
Steven
Can i just use grade 8 lock washers under the arp bolt?
Tremec TKO 600
post #5 of 50 (permalink) Old Mar 19th, 19, 09:15 AM
Vega$69's Avatar
If I remember arp washers are beveled on one side.
I would figure out what’s up and get the correct arp washers
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #6 of 50 (permalink) Old Mar 19th, 19, 09:34 AM Thread Starter
Steven
I did order a new set. If they dont fit either then arp has a big qc issue
Tremec TKO 600
post #7 of 50 (permalink) Old Mar 19th, 19, 10:50 AM
kevin
a grade 8 hardware is grade 8. get grade 8 bolts and washers from your local hardware store and forget it
some people are money people. they have to have name brand, but in reality non name brands are just as good
not sure how long arp has been around, but I am sure people used hardware grade 8 bolts before them
post #8 of 50 (permalink) Old Mar 19th, 19, 11:29 AM Thread Starter
Steven
So grade 8 bolts with lock washers torqued to factory specs?
Tremec TKO 600
post #9 of 50 (permalink) Old Mar 19th, 19, 01:53 PM
OP
+1 on get another set from whoever you got them from. Mis-packaged, happens.
ARP are excellent fasteners.
IDK, but it was noted in this thread that the washers may be beveled. If so, "generic" grade 8 won't sit the same way
My LT1 has specific PP bolt. IDK about LS motors but would not be surprised they are not just standard bolts
SoCal805 is online now
post #10 of 50 (permalink) Old Mar 19th, 19, 03:37 PM
Pressure plate bolts are not the same as a grade 8 bolt from the hardware store. The difference is the bolt has a longer shoulder that fits into the countersunk hole in the flywheel. This centers the pressure plate and stops it from developing a vibration. Can you use grade 8 bolts from the store? Yes, but they are not the same bolt.
ARP makes a great product. I would call and let them know you are having an issue.
Good luck with your project
MJK-4 is offline
post #11 of 50 (permalink) Old Mar 19th, 19, 03:44 PM
kevin
just asking a ?. did any 67,68 69 Camaro or even the corvette come with arp bolts. factory grade 8 worked then. worked with all the hi-po engines back in the day. they will work now unless you are building funny car or top fuel engine
I have a 540 horse SB and the only arp bolt I am using is for the heads. just because I lost the original bolts
torque your hardware grade 8 bolts and washers to factory specs and forget it. mine has been together for 8 years
stamatisg1977 likes this.
post #12 of 50 (permalink) Old Mar 19th, 19, 03:53 PM
kevin
they are a 3/8-16 bolt nothing special about them
if you can show me in the manual where there are a special bolt I will GREATLY APOLOGIZE
I have hundreds of 3/8" bolts with different shoulder lengths
post #13 of 50 (permalink) Old Mar 19th, 19, 03:56 PM Thread Starter
Steven
the arp bolts i have are not for the shouldered holes in my flywheel.
full thread from under the head to the tip
my clutch is centered by the dowel pins
and yes can easily be replaced by hardware store grade 8 or higher bolts
i actually ordered grade 10 flange bolts with lock washers from bolt depot. if this new pack of arp bolts are crap again im gonna use them total cost was under $5
Tremec TKO 600
post #14 of 50 (permalink) Old Mar 19th, 19, 04:22 PM
The question today with grade 8 bolts has to do with confidence that the bolt is as represented. Lines on the head don’t mean sh** in China. ARP is a reliable source. Good bolts have a radius under the head. Good washers have a corresponding radius. They should be assembled that way, especially with SAE washers.
3d cad is offline
post #15 of 50 (permalink) Old Mar 19th, 19, 04:24 PM
kevin
I know head holt washers are. not sure about others. never used them.
I lied! the last engine I bought had all arp bolts
first one to break was the valve cover studi then cut the head off a usa made grade 5 bolt and used it
Subframe Body mount bolt just spins Just 1 More Body Shop 12 Mar 11th, 19 04:43 PM
U Bolt size 69 12 bolt ? Craig1969 Transmission & Driveline 2 Mar 11th, 19 12:21 PM
An Evolving Problem CityguyUSA Engine 10 Dec 31st, 18 07:52 AM
Cracked Off Front Fender Bolt - 1968 BronzeDevil Body Shop 25 Oct 17th, 18 07:20 PM
head bolts flat tire Engine 2 Feb 2nd, 18 11:53 AM
