TKO 600 Reverse sucks - Team Camaro Tech
 10Likes
post #1 of 17 (permalink) Old Apr 15th, 19, 05:03 AM Thread Starter
DT
Donny
DT's Avatar
Wow, Now that I'm putting some mileage on my LS swap (LS3/TKO) I'm experiencing the common complaints I have been reading about with this TKO. Reverse sucks LOL. If I don't go into 4th BEFORE reverse it will grind. I guess one can live with that, but you would think this day and age they would of came up with a solution.
DT is online now
post #2 of 17 (permalink) Old Apr 15th, 19, 07:02 AM
Re: TKO 600 Reverse sucks
Jack rear of car up so tires are off ground. Start motor, put in reverse with the clutch all the way down with parking brake off.....do the rear tires move?
If so you have a disengagement issue.
what shifter/linkage do you have?
dale68z likes this.
SoCal805 is offline
post #3 of 17 (permalink) Old Apr 15th, 19, 08:05 AM Thread Starter
DT
Donny
DT's Avatar
McLeod hydraulic set-up.
DT is online now
post #4 of 17 (permalink) Old Apr 15th, 19, 08:45 AM
keith
X-77 keith's Avatar
Reverse in a TKO is not synchronised. That's why you have to go into another gear to make it go in. Its just the way they are.
DT likes this.
X-77 keith
X-77 keith is offline
post #5 of 17 (permalink) Old Apr 15th, 19, 08:57 AM
same hydraulics I have with my McLeod twin disc clutch. The MC is made by Wilwood. My MC is adjustable to raise/lower pedal. I raised it enough until I got full disengagement. Take baby steps in turning the rod until rear tires stop moving with clutch fully depressed.
You may not have a disengagement issue causing it to be hard to get into reverse but its a simple check to see if your clutch is fully disengaging by doing the check method I posted. Forward gears are syncro so you can get into 1st with minimal clutch drag but reverse is non syncro so you can't.
If disengagement is not the problem than maybe your shifter is potentially hanging some going into reverse.
Also I found Redline D4 tranny fluid really smooths out the shifting, especially in cold first shifts
In the end you may just be experiencing...well Tremac transmissions...shifting into a forward gear then reverse sometimes is needed. If that method is what you have to do and it goes into reverse easily that way...you likely do not have a disengagement issue but if it still gives resistance...check to see if the clutch is fully disengaging
DT likes this.
SoCal805 is offline
post #6 of 17 (permalink) Old Apr 15th, 19, 11:20 AM Thread Starter
DT
Donny
DT's Avatar
Thank you!
X1169 likes this.
DT is online now
post #7 of 17 (permalink) Old Apr 15th, 19, 11:40 AM
Ed
Correct! I had one in a 2001 Mustang and that's exactly what I had to do every time I wanted to put it in reverse. I just lived with it.
DT likes this.
ZEN357 is offline
post #8 of 17 (permalink) Old Apr 15th, 19, 02:08 PM
Normally a Muncie will do the same without shifting into a forward gear first.
ckaram likes this.
Dave Nelson is offline
post #9 of 17 (permalink) Old Apr 15th, 19, 05:42 PM
Dale
The tko in my 68 firebird goes into reverse with no issues. I have a stock clutch and linkage.
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #10 of 17 (permalink) Old Apr 15th, 19, 07:03 PM
Chick
68camaroz28's Avatar
As Keith communicated the TKO 600 does not have a synchronized reverse gear but when going from being in a forward gear, pushing in the clutch and going to reverse there is no issue or at least with ours. When there is an issue is if I have the car running and trans in neutral and clutch out, and then push in the clutch and try to go to reverse that's when there is an issue, as that's when the trans needs to be placed in a forward gear prior to going to reverse for a smooth transition.
DT and ilikeike like this.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #11 of 17 (permalink) Old Apr 16th, 19, 01:47 PM Thread Starter
DT
Donny
DT's Avatar
Yep 3rd to reverse much much better. Even better than 4th to reverse.
DT is online now
post #12 of 17 (permalink) Old Yesterday, 07:25 AM
Ed
Even so, the TKO600 is an outstanding Transmission. I wish I would have swapped it out sooner.
DT likes this.
ZEN357 is offline
post #13 of 17 (permalink) Old Yesterday, 07:39 AM Thread Starter
DT
Donny
DT's Avatar
I only have about 40 miles on the car now. Minor bugs to work out, NB.
DT is online now
post #14 of 17 (permalink) Old Today, 06:50 AM
Ed
It took some time to get mine broke in. I didn't drive the car very much so I can't give you a good estimate on break-in period.
DT likes this.
ZEN357 is offline
post #15 of 17 (permalink) Old Today, 07:25 AM
Kip
I had the same issue... Best cure for that issue= T56 Magnum....
1967 SSRS
kv67ssrs is offline
TKO 600 shifter stick jigsaw Transmission & Driveline 5 Apr 9th, 19 02:20 PM
TKO with 3:30 gears and 600 ft/lbs? RSSSfanatic Transmission & Driveline 1 Feb 9th, 19 09:14 AM
1969 Camaro - LS3 TKO 600 Flaming River R&P ctgoll LSx Swap 1 Nov 10th, 18 01:31 PM
Tremec TKO 600 speedo cable location jimsl78 Camaro Tech 6 Nov 4th, 18 04:22 PM
clutch stop for 1969 camaro with tko 600 Buddy z/28 Transmission & Driveline 5 May 28th, 18 04:54 PM
