Correct Gear Size - Team Camaro Tech
 5Likes
post #1 of 19 (permalink) Old Apr 17th, 19, 02:20 PM Thread Starter
Apprentice
Correct Gear Size
Hello, I have a decision to make and would like your opinions, I have a 68 camaro with a very well built 350 engine, TH350 with shift kit and 2500 RPM stall converter, I'm now building my rearend with mosier posi and need a opinion on what gear, 411(410) vs 373 gears
I drive it occasionally to car shows and around town some. Not a daily driver but I want to take full advantage of hp I have in motor. I had another 68 camaro years ago and I had 12 bolt posi with 411 gears and it ran great but I had a 2 speed powerglide in it. I've had some tell me 411 would be too low in this car being it has a TH350. What's your opinion??
Jaxfire307 is offline
post #2 of 19 (permalink) Old Apr 17th, 19, 02:48 PM
Re: Correct Gear Size
Some are not aware that the final gear ratio is 1:1 in both the PG and the TH350, so both cars will react the same with the 4.10/4.11 gear (two different gears with a different number of teeth on the ring and pinion).
I doubt if you don't drive it much if you would notice the difference between a 3.73 and the 4.10/4.11.
Big Dave
Larger Dave is offline
post #3 of 19 (permalink) Old Apr 17th, 19, 04:14 PM
Freddie
If you are ever going to get this out on the highway you will not like either of those ratios. Something in the 3.36-3.23-3.31 would be much better and still perform well.
'69 RS/SS396 pro street/427/4spd/9"
big gear head is offline
post #4 of 19 (permalink) Old Apr 17th, 19, 07:13 PM
I have a 68 with a 3 speed th350 and 12 bolt posi. It had 4.10s that I geared up to 3.42. I had a shop do the change and for the money it wasn't worth it to go any lower than the 3.42. its so much nicer to drive above 50 mph now.
DT likes this.
AlamocitySS is offline
post #5 of 19 (permalink) Old Apr 17th, 19, 07:27 PM
keith
X-77 keith's Avatar
Big gear head is not far off. Done the 4.10, and the 3.73 thing. If I had to do it again , j would not go over 3.55. Just my thoughts.
X-77 keith
X-77 keith is offline
post #6 of 19 (permalink) Old Apr 17th, 19, 08:36 PM
Lonnie
Lonnie P's Avatar
What you do not mention is how big of a tire you are running.
My Camaro with 4.10's & a 26" tire is miserable on the highway... at 3500rpm cars are still passing me.
If you drive to shows less than 20mi away & want performance, then 4.10's it is.
If you want to drive over an hour, you should consider less gear.
My best advice is to go with 4.10's & get a 700R4 trans. It will transform the car.
It's like a 2.88 on the highway plus a killer launch. I drove my Nova everywhere including 150mi plus trips with a 700R4 & 4.56's, although I admit the first gear was a little steep... unless you not afraid to rev it high.
68rs406 likes this.
Lonnie P is offline
post #7 of 19 (permalink) Old Apr 18th, 19, 05:33 AM
DT
Donny
DT's Avatar
Originally Posted by x-77 keith View Post
big gear head is not far off. Done the 4.10, and the 3.73 thing. If i had to do it again , j would not go over 3.55. Just my thoughts.
x2.
DT is online now
post #8 of 19 (permalink) Old Apr 18th, 19, 02:51 PM
4.10's 65mph 3500ish rpm....gets old quick anymore (guess I'm getting there too?)
68 Camaro~LSx ~all motor
post #9 of 19 (permalink) Old Apr 18th, 19, 05:06 PM
scblucam's Avatar
3:73, 3000 RPM, 60 MPH w/26" tire
68 302 M20 - 85 IROC Z
scblucam is online now
post #10 of 19 (permalink) Old Apr 18th, 19, 05:24 PM
Rick
You’ll miss it.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #11 of 19 (permalink) Old Apr 19th, 19, 07:29 AM
there are online calculators you enter your tire size and rear gear ratio and it will tell you what your RPM is. On transmissions with a final gear ratio of 1:1 (Powerglide, Turbo 350, Muncie 4 speed) the RPM's will be the same. Overdrive transmissions allow more rear end gear as they are generally .75:1 and a T56 .50:1
I have a T56 with 4:10's in another car running a 27" tire and at 80 MPH I am 19xx RPMs in 6th
700R4 is a OD automatic but it has a HUGE gap in ratios between 1st and 2nd gear
I had 3:73 in a Powerglide car and the RPM's at 80 mph were stupid. Yeah it was fun stop light to stop light. Put in 3:08 I had and a Turbo 350 and , for me, the car is good on acceleration yet not stupid RPM's at 75 mph. I drive the car long distances
SoCal805 is online now
post #12 of 19 (permalink) Old Apr 19th, 19, 08:13 AM
Greg
I had 3.55's when I had my TH340 in and it was ok, but too much with the increased speeds on the highways now. I have 3.73's now but I also have a 4L70E with OD and it is great. I would hate driving it if I didn't have OD if I went on the highway at all.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #13 of 19 (permalink) Old Apr 19th, 19, 08:23 AM
Darin
ilikeike's Avatar
3.55 is borderline if you do any driving on the interstate highways.
You’ll be in the slow lane. I’ve had two cars with no OD and 3.55. Just going a few exits on the highway was all I did, or would want to. If you don’t do much 65mph and up cruising, put in what you like.
I have friends with the same 3.50ish gears (ford/gm rears )and no OD. We try to keep back road cruises under 65 just for them.
Half of us run 5/6 spd. With 3.50 and up gears. I’m going from 3.50 to 3.70 right now.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #14 of 19 (permalink) Old Apr 19th, 19, 09:38 AM
keith
X-77 keith's Avatar
Yup, that's why I went TKO. I am now doing close to 2600 @80 mph. 235-60-15 tire.
X-77 keith
post #15 of 19 (permalink) Old Apr 19th, 19, 11:10 AM
kevin
10.9.9.-1 540 horse sb engine, 26" tire. 3:55 gear. Muncie 4 speed with a gear vendor over drive
55 mph in od =1900 out =2300
60 mph in od =2000 out =2600
70 mph in od =2300 ,,,,,,,,,,,,,,
80 mph in od =2600,,,,,,,,,,,,,,,
I get 13.5 to 15 mpg depending on my foot
flat tire is offline
350 turbo drive gear blues luckycharms1960 Transmission & Driveline 1 Nov 5th, 18 03:11 AM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 09:37 AM
Correct speedo gear for 2.73 rear?? fairfax1000 Transmission & Driveline 0 Mar 17th, 18 06:55 PM
ZZ502 melonized distributor gear excessive wear Gyrine Engine 10 Feb 12th, 18 12:48 PM
M-22 Wide, Close or 5-Speed for Highway Driving? Brettallen59 Transmission & Driveline 58 Dec 16th, 17 04:45 AM
