Need new Drive Shaft - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 18th, 19, 08:59 AM Thread Starter
Bobby
Performing a LS3 engine swap, when the time comes where should I try and order a new Drive Shaft from?
My YouTube LS3 Engine Swap Page
My LS3 Engine Swap Thread
Sixty8Camaro is offline
post #2 of 8 (permalink) Old Apr 18th, 19, 09:27 AM
DT
Donny
DT's Avatar
Re: Need new Drive Shaft
Mine came with my SST kit. I just had to give them my measurements. The driveshaft actually came from Dynotech 1-800-633-5559. I'm sure any driveshaft shop can handle your request though. Here is one that may be close to you? Precision Shaft Technologies
DT is offline
post #3 of 8 (permalink) Old Apr 18th, 19, 09:31 AM
Darin
ilikeike's Avatar
I just had one built locally when I needed one,
with 1350 spicer joints it was about $300. Took a day or two.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is online now
post #4 of 8 (permalink) Old Apr 18th, 19, 11:04 AM
kevin
Dennys
flat tire is online now
post #5 of 8 (permalink) Old Apr 18th, 19, 11:58 AM
I just ordered a new driveshaft from Strange Engineering (purchased thru Jegs). Jegs does not list all of the Strange Engineering driveshafts on their website... but if you have the part #s you want, just call them directly and they can order one for you. There is a driveshaft order worksheet that you download to determine the correct length needed. Jegs has very good pricing plus free shipping (and a discount coupon can also be applied if ordered at the right time).
NOTE: Be sure to order a driveshaft diameter based on the length that is needed to keep your intended maximum RPMs about 80% of the driveshaft's critical speed.
Critical Speed Chart | Precision Shaft Technologies
You also want to select a driveshaft diameter that does not match 1/2 critical speed based on your normal cruising RPMs. If you have an overdrive transmission, remember that your driveshaft is turning faster than the engine RPMs.
oldschoolchevy is offline
post #6 of 8 (permalink) Old Apr 18th, 19, 12:16 PM
Originally Posted by flat tire View Post
Dennys
^^^^^^THIS!!
I have one on another car and would only use them again. They are one of the few shops that can spin balance up to 10k rpm
When I went 4:10's in my other car the stock DS, even after re-balance, was not enough
SoCal805 is online now
post #7 of 8 (permalink) Old Apr 18th, 19, 12:31 PM
Travis
Tom Woods - built and shipped the same day you order or the following day.
travisch is offline
post #8 of 8 (permalink) Old Apr 18th, 19, 01:31 PM
Found a place on ebay, it was a drive shaft shop in Ohio I think....cheaper than I could get locally
Working great so far....forget what it was rated for HP wise.
68 Camaro~LSx ~all motor
Drive shaft wall thickness? tri 6's fanatic Transmission & Driveline 5 Mar 29th, 19 07:04 PM
Drive shaft length Heftyspencer88 Transmission & Driveline 10 Mar 17th, 19 07:47 AM
Wonít stay running; wrong plugs.?.? Boucher421 Engine 43 Nov 28th, 18 07:34 PM
Drive shaft colors old person Transmission & Driveline 5 Aug 19th, 18 06:13 AM
Calibrate TH400 Speedometer Drive Andrew69 Transmission & Driveline 13 Apr 28th, 18 05:00 PM
