8.2-inch 10-bolt - Team Camaro Tech
 3Likes
  • 1 Post By DOUG G
  • 1 Post By Vega
  • 1 Post By big gear head
post #1 of 4 (permalink) Old Jun 18th, 19, 06:21 PM Thread Starter
DaveS44's Avatar
8.2-inch 10-bolt
Are 8.2-inch 10-bolts worth upgrading to posi?
How much power can they handle? Mild 350 with 700R4 is the plan.
ID:	227711   Click image for larger version
1969 Plain Jane Coupe
DaveS44 is offline
post #2 of 4 (permalink) Old Jun 18th, 19, 06:31 PM
Re: 8.2-inch 10-bolt
I ran an Eaton posi and was in the 11's with no issues.
Eric68 was in the 10's before he broke an axle shaft (but it is the same size shaft as a 8.5")
IF set up right, it should live. Now IF abused, all bets are off. (even 2.5T military axles break when abused )
I would suggest aftermarket axles too IF/WHEN you can.
DaveS44 likes this.
68 Camaro~LSx ~all motor
post #3 of 4 (permalink) Old Jun 18th, 19, 06:58 PM
Vega$69's Avatar
I see no problem with a 10 posi unless you have crazy power and sticky tires.
Above all avoid wheel hop. That will kill even the best built rear ends.
DaveS44 likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 4 (permalink) Old Jun 19th, 19, 04:42 AM
Freddie
I built a 8.2 for a friend's '69 Camaro that had a 383 and a 4 speed. He was lifting the front tires on the drag strip and it didn't break. You should be fine with the 350 and 700R4 on the street.
DaveS44 likes this.
'69 RS/SS396 pro street/427/4spd/9"
big gear head is offline
