camaro 89 best rear gear ratio - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 9th, 19, 11:34 PM Thread Starter
Probationer
hi i got camaro 89 rs with a v8 305 tbi and looking for best gear ratio for a 700r4 transmission used to have 2:73 but not anouph strong put 3:73 its to much rpm on highway so thinking 3:23 or 3:42 what you guys are thinking be the best for regular street used
ti-west is offline
post #2 of 12 (permalink) Old Jul 10th, 19, 03:31 AM
keith
X-77 keith's Avatar
308-342 would be my choice. Somewhere in that range. If you don't like the 373, the 342 is not going to feel much different. 308 is a decent all around gear.
X-77 keith
X-77 keith is online now
post #3 of 12 (permalink) Old Jul 10th, 19, 04:04 AM
Vega$69's Avatar
Re: camaro 89 best rear gear ratio
3.73 is 2350 rpm at 70 MPH. 2.73 is 1750.
What rpm are you looking for?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 12 (permalink) Old Jul 10th, 19, 06:29 AM
Ed
I agree. Go with 3.08. I own a 1991 Z/28 with the 305 TPI/5-Speed and I have 3.73's but it has the 5-Speed. I probably should have went with 3.42's but I wanted more off the line speed. I don't drive it much though so highway mileage doesn't really matter to me.
Richmond Gear 3.08's
https://www.jegs.com/i/Richmond-Gear...791+4294829509
Richmond Gear 3.42's
ZEN357 is offline
post #5 of 12 (permalink) Old Jul 10th, 19, 06:33 AM
OP
use a RPM calculator using your tire size
https://spicerparts.com/calculators/...rpm-calculator
700R4 has a low 1st gear so 3:08 would still be quick off the line and OD RPM's would be conservative.
You can insert different gear ratios in calculator and see what RPM at what MPH and make a decision
On any gear change, if you do not already have a Posi...good time to install one.
SoCal805 is online now
post #6 of 12 (permalink) Old Jul 10th, 19, 06:34 PM
Bobby
I'd leave the 3.73 with the overdrive trans
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #7 of 12 (permalink) Old Jul 10th, 19, 07:31 PM
scblucam's Avatar
My stock 85 IROC Z came with the 3.42 and is very drivable and will do 130 mph on the way to a poker game.
68 302 M20 - 85 IROC Z
scblucam is offline
post #8 of 12 (permalink) Old Jul 11th, 19, 06:52 AM
Apprentice
George
Good info, thanks.
1968 RS z28 Corvette Bronze
Magoo is offline
post #9 of 12 (permalink) Old Jul 11th, 19, 07:03 AM
Greg
I had an 87 IROC that I put 3.23's in and it was great.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #10 of 12 (permalink) Old Jul 11th, 19, 10:03 AM
I had an 84 Z28 with a 5 speed. When I blew the 3.73 rear I put a 3.42 in it and couldn't tell much of difference. Even with the HO 305 (G) and a manual trans it was a serious slug. Yours is an RS without the HO if I'm not mistaken. Not that it makes much difference at, what was mine? 190 hp? If you put higher gears in it you'll feel like you're driving a Yugo.
There's a big misconception about tall gears and gas mileage in a lot of cases. Especially older cars. If you don't have enough power your engine is doing twice the work and using more gas.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1
Semper Fi!
HawkX66 is offline
post #11 of 12 (permalink) Old Jul 11th, 19, 10:23 AM
mike
I like the 3:73 with 700r4 in my truck along with the Eaton posi.
1967 convertible T-1
Hogdaddy is online now
post #12 of 12 (permalink) Old Jul 11th, 19, 12:39 PM
rear gear....it really depends on what tire size and RPM's you can tolerate at FWY speeds.
If the car is just a short trip (read just a few exits of Fwy driving) stop light to stop light car than low gear ratios are the fun factor
IMHO use a rpm calculator using your tire size and tranny type to see what RPM's at what speeds you will have and pick the ratio that suits your tolerable RPM's at the speeds you mostly drive
or just be the car at 55 mph in the slow lane on Fwy if you want a street or 1/4 mi warrior with a 1:1 final gear tranny. OD tranny helps but IMHO anything over 342's for those and the RPM's are up there at 70 mph with a 700R4 OD trans.
I have a T56 car with 4:10's running a 27" tall tire and with a .50 6th I am just under 2k RPM at 80...so if you have a real high gear OD trans you can run a low gearset in the rear
