T56 magnum clutch options? - Team Camaro Tech
 2Likes
post #1 of 18 (permalink) Old Nov 29th, 19, 08:40 PM Thread Starter
I'm putting together a list of parts for my TH350 to T56 magnum swap.
Does anyone have the part number for the proper McLoed twin disc clutch and TOB?
1968 camaro
EVL SS is offline
post #2 of 18 (permalink) Old Nov 29th, 19, 08:41 PM
Jody
Re: T56 magnum clutch options?
PM Sent
Jody Haag
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-413-8015
JodysTransmissions is offline
post #3 of 18 (permalink) Old Nov 30th, 19, 08:44 PM Thread Starter
Anyone?
1968 camaro
EVL SS is offline
post #4 of 18 (permalink) Old Dec 1st, 19, 04:56 AM
Vega$69's Avatar
Why do you want a twin disc? There are very good dual friction clutches for a lot less $
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 18 (permalink) Old Dec 1st, 19, 07:09 AM
Chris
130fe's Avatar
How much power are you dealing with? HP?
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #6 of 18 (permalink) Old Dec 1st, 19, 08:00 AM Thread Starter
I will be building a motor soon but, hoping for 650hp.
1968 camaro
EVL SS is offline
post #7 of 18 (permalink) Old Dec 1st, 19, 08:39 AM
I am in the same boat as you Dave. I have McLoeds +.4 flywheel. They say the 6932-07 clutch setup fits that wheel. Thats the rxt part number. They have it catalogued mainly as a Ford part it seems with LS apps as a footnote. I am leaning towards the twin disc in the hope it matches up better with my trashed left ankle. I still have some clutch pieces from back when that should handle the power, do fit this flywheel, but might not be compatible with the ankle. I still have some time yet before i need them.
EVL SS likes this.
3d cad is offline
post #8 of 18 (permalink) Old Dec 1st, 19, 09:42 AM
Vega$69's Avatar
Go with a hydraulic Clutch for easy pedal effort.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #9 of 18 (permalink) Old Dec 1st, 19, 09:46 AM
Vega$69's Avatar
What engine? NA or Boosted?
Not HP but Torque is what matters in a clutch requirement.
IMO you should figure out the engine 1st then decide on the best clutch for your combo and the way you intend to use the car.
130fe likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 18 (permalink) Old Dec 1st, 19, 09:51 AM
What changes in the hydraulic setup John? If at the end of the disengagement the pressure plate and pedal have the same travel there is no change in mechanical advantage and no change in force required other than the losses produced by linkage resistance, which can be considerable.
Do you know if McLoeds hydraulic setup interferes with Wilwoods balancing valve mount assuming no power booster? The pics I see of the hyd clutch assembly seem to point that way.
3d cad is offline
post #11 of 18 (permalink) Old Dec 1st, 19, 10:12 AM
Vega$69's Avatar
The Hydraulic makes pedal pressure very easy compared to the OEM Z Bar set-up. Sit in a new Camaro or Vette and feel the effort.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 18 (permalink) Old Dec 1st, 19, 11:45 AM
OP
if you will be making 650 RWHP and similar TQ you want a twin disc clutch vs a single disc DF one. Street manners are smooth sailing with full face organic disc Twin clutch (McLeod RST). If its all about he 1/4 mi than get the RXT
While not in my Camaro I have the McLeod twin in another Chevy 383/T56 car and it is WAY better than any single disc, regardless of composition, I have used. I also have the McLeod (Wilwood) MC (hydraulic clutch), nice unit. If this is a LSx car than use stock size bore MC
SoCal805 is offline
post #13 of 18 (permalink) Old Dec 1st, 19, 12:25 PM Thread Starter
Originally Posted by SoCal805 View Post
OP
Thanks for the insight. Yes, +/- 600tq is where I hope to be. No boost, just a NA motor with no nitrous. I don't know if that will change in the future but, I don't think so.
1968 camaro
EVL SS is offline
post #14 of 18 (permalink) Old Dec 1st, 19, 03:04 PM
Vega$69's Avatar
The best clutch I had was a Mantic Twin Disc.
SBC, BBC, LS?
How are you going to achieve your 650/600 numbers NA?
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #15 of 18 (permalink) Old Dec 1st, 19, 05:12 PM
Simon
slazisme is offline
