Clutch engagement issue on new T56 - Team Camaro Tech
 3Likes
post #1 of 17 (permalink) Old Dec 11th, 19, 06:17 PM Thread Starter
Alex
I just wrapped up the install of my T56 Magnum from SST. I received the driveshaft and tossed it in thinking I would go for a test drive. Well, nope. I'm going to call them for assistance tomorrow but I thought I would post and see if anyone had any ideas I would try tonight.
The issue is that my clutch seems to be not engaging. Bleeding seemed to go well, although it did take a while. The pedal feel is high, but other than that, feels totally normal. I was able to put eyes on the hydraulic throw-out doing it's job while down there bleeding as well. When I started the car, I go to put it in gear, but I can release the pedal fully and nothing happens. I able to freely put the car in any gear with the pedal all the way out.
So when I say the pedal is high, I can feel it start to have pressure on it after only maybe 1/2" of travel, if that. Do you think it's just a case of having the adjustment linkage out of whack? When I installed the clutch master and the pedals, I adjusted it so that the rod was just perfectly totally extended with like 1/16" of the inch of travel in the pedal until the arm lined up perfectly with the clevis pin. The pedal returns as it should and has a good feel. Do you think I just need to adjust the linkage so the pedal starts to stiffen lower? I'm not sure I could do it much more because the adjustment rod really doesn't have any adjustment left in it. Maybe 1/4" at most available to shorten it.
For what it's worth, I'm 100% sure I got all of my measurements right for the spacers and that I put the clutch together properly. I hope I didn't overextended my clutch master of the throw-out, or bend the clutch fingers.
Thanks!
1969 Pontiac Firebird
w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black w/black interior.
1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
anguilla1980 is offline
post #2 of 17 (permalink) Old Dec 11th, 19, 06:21 PM
Vega$69's Avatar
Re: Clutch engagement issue on new T56
Maybe a stupid question but Iíve seen it happen.
Did you install the clutch disc?
Vega$69 is offline
post #3 of 17 (permalink) Old Dec 11th, 19, 06:23 PM Thread Starter
Alex
Haha, yes. Both of them. I did the test bench assembly to take required measurements so that familiarized me with how it went together. I'm sure everything is the correct direction and assembled per the instructions from RAM.
post #4 of 17 (permalink) Old Dec 11th, 19, 06:27 PM
Vega$69's Avatar
Was the TO bearing fully compressed when you took measurements?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 17 (permalink) Old Dec 11th, 19, 06:33 PM Thread Starter
Alex
Yup. I pushed on it hard as I could to see what fully compressed looked like, then made sure it was the same when I measured.
Would it help if I posted all of my measurements?
post #6 of 17 (permalink) Old Dec 11th, 19, 06:34 PM
Vega$69's Avatar
Open the bleed valve and see fluid squirts out with the pedal up. The close the valve and see if it will engage.
Vega$69 is offline
post #7 of 17 (permalink) Old Dec 11th, 19, 06:43 PM Thread Starter
Alex
Ok, I'll go jack the car up and check.
post #8 of 17 (permalink) Old Dec 11th, 19, 06:48 PM Thread Starter
Alex
Looking back over my notes, I think I see where I screwed this up.
From the clutch fingers to the outside of the bellhousing = 2.128"
From the trans face to the face of the TO = 1.850"
2.128 - 1.850 = 0.278"
The spec asked for between 0.125" and 0.375". It looks like I was right on the money with zero spacers but I put both 0.25" spacers in they included.
That means I'm 0.788".
Dammit. I'm going to have to remove this thing and hope I didn't screw something up. I can't believe I did that.
post #9 of 17 (permalink) Old Dec 11th, 19, 06:51 PM
Vega$69's Avatar
Yep. Thatís most likely the issue. Easy fix just sux to pull the tranny to fix it.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 17 (permalink) Old Dec 11th, 19, 06:53 PM Thread Starter
Alex
Yeah I'd say that's for sure it. Really going to suck pulling it. After I got it in, I thought I never wanted to do that again. JINX!
Thanks for the help. It was good to talk it through with someone.
I'll probably do this 2nd half of January when I'm back from vacation.
Man I sure pray that 1/2" I was over extending the clutch fingers while I was bleeding it all those times the pedal was pushed didn't ruin it
post #11 of 17 (permalink) Old Dec 12th, 19, 12:49 AM Thread Starter
Alex
Took this old man 4hrs to get it back out and in again for the 2nd time. I was hustling and on a mission. I'll test drive in the morning. Didn't want to wake up all my neighbours with my exhaust so late.
ilikeike likes this.
post #12 of 17 (permalink) Old Dec 12th, 19, 06:16 AM
Vega$69's Avatar
Hope it's good to go.
Too late now but a simple check would have been to loosen the 4 transmission bolts and slide the tranny back 1/4". Engine NOT running put the car in gear, E-brake off and push the car. If it doesn't move the clutch is engaged and the issue is TO bearing clearance.
You can do it now that it's back together without starting the engine to verify it's engaging .
Vega$69 is offline
post #13 of 17 (permalink) Old Dec 12th, 19, 08:06 AM
yes OP, but I guess you figured it out now
You could just jack up the rear so tires are off ground. Push in clutch with car in gear and rear wheels should freely turn by hand (need 2 people to do this). Then let out clutch while still in gear...rear tires should not move
of course doing it with engine running and just watch rear wheels start when pedal is released while in gear and roll to a stop when you push in clutch
Have done a "this trans never came in this car" on a A4 to T56 swap before and had the trans out several times during that mod to get everything right...
SoCal805 is offline
post #14 of 17 (permalink) Old Dec 12th, 19, 09:50 AM Thread Starter
Alex
I'll give it a test today in a few hours. Just need to reinstall the shifter lever.
post #15 of 17 (permalink) Old Dec 12th, 19, 11:02 AM
Vega$69's Avatar
Good Luck.
When I bleed the clutch master I have the car in gear with the e-brake off. Wheel chocks a few inches in front and back of the tires.
With my helper pushing clutch pedal during bleeding I push the car back and forth to confirm the clutch is releasing.
anguilla1980 likes this.
Vega$69 is offline
