Back up light - Team Camaro Tech
 13Likes
  • 1 Post By flat tire
  • 1 Post By Vega
  • 1 Post By adjudimo
  • 1 Post By bob15
  • 1 Post By Old Dad's 67
  • 1 Post By SSsedan
  • 2 Post By SoCal805
  • 5 Post By Vega
post #1 of 13 (permalink) Old Jan 11th, 20, 09:46 AM Thread Starter
Back up light
Hi I have a 69 that was born a Auto now its a 4sp Saganaw has anyone installed Back up lights
not sure if its a big deal or no to bother with them Thanks
Kelcel is offline
post #2 of 13 (permalink) Old Jan 11th, 20, 09:58 AM
kevin
Re: Back up light
it can be done with linkage.
the simplest way is with a toggle switch if you must have them
a backup camera with night vision works great and is just as easy to install as would your backup lights
check e bay or amazon
Kelcel likes this.
flat tire is offline
post #3 of 13 (permalink) Old Jan 11th, 20, 10:01 AM Thread Starter
Re: Back up light
Great thanks for that i will look
Can you tell me then what wire needs to be powered for the back up lights i have 5 wires that were in the Neutral Safety switch plug White Pink Brown Orange and Green Thanks !!
Kelcel is offline
post #4 of 13 (permalink) Old Jan 11th, 20, 02:03 PM
Vega$69's Avatar
Re: Back up light
You'll need the linkage and back up light switch installed
Name:	Back up Light Wiring.JPG
Kelcel likes this.
Vega$69 is offline
post #5 of 13 (permalink) Old Jan 11th, 20, 06:20 PM
Re: Back up light
I consider back up lights a safety issue/requirement. Not so much to help you
see but so others can see you are backing up.
my 67' build thread:
allanjs is offline
post #6 of 13 (permalink) Old Jan 11th, 20, 08:07 PM Thread Starter
Re: Back up light
Attachment 231875
Thanks for that i will look into a switch and i see the green wire needs power for the back up lights Thanks
Kelcel is offline
post #7 of 13 (permalink) Old Jan 12th, 20, 12:10 AM
J.R.
Re: Back up light
Or you could install a toggle switch like Kevin (flat tire) mentioned above that lights up when activated. Just a matter of hooking up positive and ground wires. Your local parts store probably has a variety to choose from. I like the small rocker type in a black housing that the button you flip lights up. Doesn't stick out much like some of the toggles that have a 1 1/2" blade protruding.
Kelcel likes this.
J.R.
adjudimo is offline
post #8 of 13 (permalink) Old Jan 12th, 20, 05:44 AM
bob
Re: Back up light
There is also the Hurst universal kit. I used this same one for many years. When I added the M22W, I installed the correct back-up light switch assembly. It cost a lot more than the Hurst switch, but it was something I just wanted. You can also just add a toggle switch inside the car and manual operate it when you go to back up.
Hurst switch:
Kelcel likes this.
bob15 is offline
post #9 of 13 (permalink) Old Jan 12th, 20, 09:11 AM Thread Starter
Re: Back up light
Hurst switch:
Thanks for that i will look into it and is it the green withe that needs power to light up the back up lights Thanks
Kelcel is offline
post #10 of 13 (permalink) Old Jan 12th, 20, 12:59 PM
Re: Back up light
Pink and green would go the B/U light switch. I used the one pictured above for my Muncie conversion with Hurst shifter. Not sure how it would work on the Saginaw.
Kelcel likes this.
Old Dad's 67 is offline
post #11 of 13 (permalink) Old Jan 15th, 20, 05:31 AM
Russ
Re: Back up light
The Saginaw transmission uses a different backup light switch bracket, because of the side cover bolt spacing. I haven't been able to find one reasonably priced after years of looking. The Hurst switch would be the easiest fix. Be aware that the bracket is on the flimsy side, and might need altered for your application.
Russ
Kelcel likes this.
SSsedan is offline
post #12 of 13 (permalink) Old Jan 15th, 20, 10:17 AM
Re: Back up light
Another option is to use a shifter ball with a button. These are typically used to activate a line lock but would do the same thing for BU lights
69Z28 and flat tire like this.
SoCal805 is offline
post #13 of 13 (permalink) Old Jan 15th, 20, 10:39 AM
Vega$69's Avatar
Re: Back up light
Back up lights primarily are to alert other drivers you’re backing up.
Aggressive exhaust serves the same purpose.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
