FW & BH bolts - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 16th, 20, 03:37 AM Thread Starter
Fabien
FW & BH bolts
Hello,
I'm changing my M20 for a T56.
Do I need to buy new bolts for the FW and BH or can I reuse mine?
Are the ARP better?
Thanks,
Fabien
limpsilver is offline
post #2 of 7 (permalink) Old Jan 16th, 20, 04:24 AM
Brett
Re: FW & BH bolts
Yes for FW replacement bolts. Not required for the Bell Housing in my opinion. ARP are the best. Only fastener I'll purchase.
Brett.....
Rockets Up In 2020!
Brettallen59 is offline
post #3 of 7 (permalink) Old Jan 16th, 20, 05:21 AM
keith
X-77 keith's Avatar
I would agree. If you have split washers on the bell housing bolts, I would put fresh washers on them.
X-77 keith
X-77 keith is offline
post #4 of 7 (permalink) Old Jan 16th, 20, 06:41 AM Thread Starter
Fabien
Re: FW & BH bolts
Thank you guys
post #5 of 7 (permalink) Old Jan 17th, 20, 06:41 AM Thread Starter
Fabien
Re: FW & BH bolts
I forgot to ask about pressure plate bolts, do I need to buy new one?
Or the question could be, do I need to buy bolts when changing clutch
post #6 of 7 (permalink) Old Jan 17th, 20, 06:50 AM
Vega$69's Avatar
Re: FW & BH bolts
I would change the bolts to ARP. Not really that expensive and better than risking a failure.
Have you resolved the vibration issue?
Vega$69 is offline
post #7 of 7 (permalink) Old Jan 17th, 20, 07:00 AM Thread Starter
Fabien
Re: FW & BH bolts
Yes the price is not the problem, it is more that I don't know which one to buy and I don't want to make a mistake.
It should be this one : https://www.jegs.com/i/ARP/070/130-2201/10002/-1
Do I have to remove the flywheel during the installation?
I'm not sure if my block is a 2 piece (replacement block form mexico), if so I need the bolts : https://www.jegs.com/i/ARP/070/100-2801/10002/
For my vibration issue, the plan is the following :
- remove the trans and clutch
- start the engine and see if I still have vibration (I'm suspecting my clutch)
- if no vibration : take a beer
- if vibration : pull out the engine, check the crank and everything you guys said on the other thread.
Fabien
